Ferrari Emergency Work Light LED | FerrariChat
Discussion in '308/328' started by Lowell, Dec 29, 2017.
  1. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    I replaced the original incandescent bulbs in the emergency work lights in my 308GTS and 330GT with festoon LED bulbs. Now they are really bright. Of course, I probably will never use them. It is interesting that the 330 work light uses the ordinary cigar lighter receptacle while the 308 work lamp uses that special receptacle under the dash.
  2. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    Lowell can you please post a pic of your 330 light.
    I've never seen one.
  3. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    The 330 light has an ordinary cigar plug as shown on the left of the photo. The 308 light has the special plug which is to the
    right of the 330 plug. The remainder of the entire 308 light assembly is above the 330 assembly. Note that except for the
    plugs, everything is the same for the 308 and the 330.
  4. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    Incidentally, wrapping the wires in two compact parts as shown on the 330 lamp makes the assembly fit into the bag
    much neater.
  5. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    I'm certainly no concours expert but I'm fairly certain that those are not factory rubber bands. Do you know where original ones might be purchased? ;-)
  6. Rossocorsa1
    Rossocorsa1 F1 Veteran
    May 14, 2017
    6,226
    The light cord came wrapped with a black plastic strap, similar to a black zip/cable tie. I will take some photos of mine this evening when I;m home and will psot them.
  7. Rossocorsa1
    May 14, 2017
    6,226
  8. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    I guess that will teach me to be such a smartass. Nice touch!
    Lester
  9. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Of course now I have to find one...
  10. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,340
    Encino, Ca
    Carl T
    Nicely done...now it can actually be useful ;)
  11. Rossocorsa1
    May 14, 2017
    6,226
    The regularly pop up on ebay
  12. Rossocorsa1
    May 14, 2017
    6,226
    Be certain you know the correct plug-in end for your car. They vary over the years and from different models. Also, in case you are unaware, lights came in a black vinyl, snap shut pouch. They pouches are rather cheap and often come with rips or tears along the heat-sealed seams. Again, I can post a photo later tonight of need be.
  13. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Misunderstanding, I have the work light and pouch just not the "correct" zip tie.
    This typing stuff doesn't translate my clever and droll wit very well.
    Milkshaker0007 likes this.
  14. Rossocorsa1
    May 14, 2017
    6,226
    Got it. Let me check. I think I know the correct source for the ties.
  15. The Singer
    The Singer Karting
    Feb 10, 2016
    113
    Toronto
    Interesting, that’s not the under dash, plug-in, used for my 1989 328 GTB Swiss Spec
  16. Rossocorsa1
    May 14, 2017
    6,226
    I believe the US cars are different. Mine plugs into the cigarette lighter on the central tunnel.
  17. Rossocorsa1
    May 14, 2017
    6,226
    Apologies - the cable tie brand I was thinking about (Colson) has a slightly different style and shape.
  18. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    yes colson
    Superformance have them
  19. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    Thanks Lowell, I had no Idea these also applied to 330.
    I have not seen any references in parts book or owners manual.
    can you enlighten me plse ?
    Howard
  20. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    I am certain that 308 emergency lamp with the special plug shown in my photo did come with my 1984 308GT QV.
    This car has a special socket under the dash that fits the peculiar plug on this lamp and does power the lamp.
    Kerry Chesbro is one of the worlds experts on 330GT cars. He does not think that the emergency lamp that plugs into
    the cigar lighter shown in my photo is correct for my late Series II 330GT. I have kept records of every part --- large and
    small --- that I have purchased for the 330. I can find no receipt for a lamp purchase. So I presume that it came with the
    car when I bought it in 2000. But it could very well be that it is not correct for a 330GT. There is a very peculiar electrical
    socket beside the choke button under the dash of the 330GT. Kerry says that this is the socket for the proper emergency lamp.
    Kerry has never seen a 330 emergency lamp and knows no one who has. However, Kerry owns a Series II PF Cab. that has
    the same socket under its dash. So all we need do is find a lamp for one of those. Since we are all in the dark about this,
    I guess we need to find the lamp to shed some light on the subject.
