Ferrari engine | FerrariChat
Ferrari engine
Discussion in 'Technical Q&A' started by jkyle69, Dec 19, 2005.
  1. jkyle69
    jkyle69 Rookie
    Jan 22, 2005
    21
    I am making a modern incarnation of an Italian GT car, I would like to install a Ferrari engine but I am not sure what to use. I was thinking about an engine from either a 360 or 550. Is this a good idea and what sort of price are these engines?
  2. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,216
    Mount Isa, Australia
    Pap
    Go for it mate,there would be plenty of 360/550 wrecks out there to get the donor engine and gearbox.But......you may receive a heart attack at the price of them! Engine,gearbox,ecu's,wriring harness................ big bucks$$$$$$. You maybe be better off,going the normal routine and putting in a poxy Ford or Chev V8?? Have fun and good luck bud!! :)
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,664
    South East
    Jimmie
    I don't want to sound negative but you might need to figure out if your GT is going to be front or rear engine - 550 is a large front engine with a rear gearbox whereas 360 is a smaller mid engine & gearbox package - either will be expensive but one more so - I'd guess you certainly do not want to mess with changing transmissions - so your design will dictate your engine - if you want a rear V12 you'll need a wrecked Lambo
  4. tr328
    tr328 Formula Junior
    Jun 19, 2003
    905
    Pacifica, California
    Darryl
    My first thoughts are "are you crazy" the price is going to be astronomical, but if money is no object, go for it. Engine/tranny $$$$$,
    Many, many other ways to go and make it a driver with no thoughts about it.
    Either way you go, Good luck!
  5. jkyle69
    jkyle69 Rookie
    Jan 22, 2005
    21
    Any recommendations from anyone of what combination to use?
  6. bwassam
    bwassam Formula Junior
    Jan 3, 2005
    635
    North Bend, Oregon
    Robert Wassam
    Take a look at how the Pantera's did it. Why reinvent the wheel?
    Bob Wassam
  7. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    I bought a brand new 365 GTC4 complete and had to pay over $20,000 for it so thats just the state of the F-engine Market. V-12's will always bring the highest prices. A 550 motor in good shape should probably cost $28,000-$30,000 or more.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    There’s a lot of stuff you need to decide. Is the engine going in the front or the back? Longitudinal or transverse?
    Just because you pick a Ferrari engine, doesn’t lock you into their transmission or transaxle, you may find something else that works better for you.
    The general rule in specing an engine for a sports car is use the biggest, highest hp engine that will fit and you’ll have a winner. So if a 12 will fit, I’d use that. You can also add a turbo or supercharger to it it it won’t make the numbers you’re looking for.
  9. jkyle69
    jkyle69 Rookie
    Jan 22, 2005
    21
    I am looking to use an engine longitudinal with a transaxle, mid-engined
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    Will the car be long enough for a 12?
    I'm sure a 550 engine could be made to work with a 360 gear box, a porsche G50 or there may be others.
    I guess its easier to just buy an engine/trany already together and have one less thing to think about, but that means 360 engine if you’re going mid-engine.
    I will point out the elephant in the room here and say that building a car is an awful lot of work. I built a couple small racecars from a pile of tubing on the floor to a running car in college and I’d guess about 3000 hours was the final total. To build a street car from scratch would be 2-5 times that depending on the materials and level of finish. There’s a reason it isn’t done often.
    On a stupider note, I have toyed with the idea of pulling molds of my 308 (which I really like) and using them and molds I build to make a carbon fiber monoque version. Same look, but ultra stiff, a little more cabin room and very light. I’ve also considered a version using a space-frame which is easier of me to build, but can be just as rigid covered with ultra-light foam core body panels…..but them I remember how much work it is and I just add a little more boost to the engine and call it a day.
  11. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    So Mike,
    How long have you had this car problem???
    chris
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,729
    The twilight zone
    I've been pondering for about 22 psi now :)
  13. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Yes go for the 22lbs. building is satisfying but also emotionally draining.
  14. rexrcr
    rexrcr Formula 3 Rossa Subscribed
    Nov 27, 2002
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    LOL, very funny Mark, I feel your pain. :)
  15. rexrcr
    Nov 27, 2002
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    You've gotta begin with writing down your goals for the performance, styling, cost, and a profile of the prospetive owner/buyer. Only then can you begin specifying hard parts. Everything is driven by cost.
    If this is just mental masturbation, then go for it... why not use both a 550 and 360 drivetrain... ???
    Best regards,
    Rob
  16. mark328
    mark328 Guest
    Jul 30, 2005
    664
    Mi
    Mark
    Post some pictures of what you have done so far.....if you plan on buying an engine from a 360 or 550 by the time your done you could have bought yourself a nice 328.
  17. DHarm
    DHarm Rookie
    Mar 16, 2004
    18
    I've been working on a similar project and watching ads. Lyle Tanner salvage in California has a complete 360 engine, trans. and ecu for sale under "used parts" for $25,000. Let us know how it goes.
