Ferrari f430 f1 clutch replacement procedure? | FerrariChat
Discussion in 'Technical Q&A' started by cascam330, Apr 7, 2015.
  1. cascam330
    cascam330 Rookie
    Mar 29, 2015
    4
    hey guys me and my mechanic friend planning to replace the clutch in f430 f1 gearbox.
    what i know is replacing the clutch is possible at a garage.
    how to replace the oil and is it necessary to reset the f1 shifting or any other procedure to be carried out pre or post replacement??
  2. Rifledriver
    37,108
    Computer operations required pre and post replacement.
    Should really only be done by those with the correct computer equipment.
  3. bowbells
    bowbells Formula Junior
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    No worries, go for it. Nuts and bolts mate.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Follow these instructions at your peril.
  5. Rifledriver
    37,108
    And people wonder why the internet is full of people having trouble with their F1 and getting poor clutch life.
    Stupid is as stupid does.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I expect that some guys enjoy sending others down a dirt road.
    How often do we see someone here with an apparent minor problem followed by a few annonymous idiots coaching them to spend huge money replacing unrelated parts as if they would do it if it was their car?
  7. Rifledriver
    37,108
    Well there certainly is an element of that.
    One thing I find interesting is how few threads people who know what they are doing respond to yet everyone gets advice.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    We're all morons and crooks donchaknow. ;)
  9. Rifledriver
    37,108
    Dewey, Cheatham & Howe
  10. vrsurgeon
    vrsurgeon F1 World Champ
    16,543
    Charleston, SC
    Curt
    Posted on June 7, 2015:
    "Help my car stopped running and my F1 light is on" -or-
    "Why won't my car stay in gear? I just put a new clutch in 2 months ago.. ?"
    My favorite: "Were we supposed to replace that o-ring between the clutch and transmission? We just put the two sections together and bolted it up... "
  11. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    As for what i remember, one needs an SD3 computer to re-calibrate the system.
  12. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,960
    The Cold North
    Tom
    I'm staying out of this one..
  13. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,732
    Even in a clutch position.........
  14. tbakowsky
    Sep 18, 2002
    19,960
    The Cold North
    Tom
    I see what you did there..;)
  15. cascam330
    cascam330 Rookie
    Mar 29, 2015
    4
  16. muk_yan_jong
    muk_yan_jong Formula Junior
    Oct 11, 2008
    569
    Brian McK
    Enough smack-in-the-face information to ask a better question or just admit you can search some more and all you give is frownyface?
  17. Rifledriver
    37,108
    Well if he takes my information at face value, which I think he should I don't blame him for being disappointed. If that is his message, I get it.
  18. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    A. plenty of threads detailing this process,you are asking how to replace the oil....?
    you want someone to lay it all out for you, implies you should not
    tackle this. Manuals available on line, have you looked ?
    B. Absolutely can be done in your own garage, as long as you have the ability.
    C. You need the clutch settings (pis) etc., read before you start,
    And reset before you drive the car, and test drive, maybe reset
    again, all using a SD2/3 or comparable ....
    D. A indie shop did mine, flat racked to dealer after mechanical
    work was done, they did the F1 fluid flush, and set all parameters.
    So answer is yes, you can do the mechanical stuff in a home garage
    but you better be ready with knowledge, tools, and parts...
    Will you replace trans mount while in there ? If you need to and do not
    have the part, down time, you could spend a lot more time, stopping
    and ordering pats than you think, this may not be a big deal but can happen.
  19. cascam330
    cascam330 Rookie
    Mar 29, 2015
    4
    After lots of search I got Ferrari f430 workshop manual.
    First let me look for a sd3 support then I ll remove and replace the clutch myself.
    Thanks for the support :D:)
    Will update the thread once its done.:cool:
  20. tazandjan
    39,182
    After you replace the clutch, you can flatbed it to someone who can do the SD3 ($25,000) work for you. Will cause some problems because you did not save some of the old parameters, but an expert can probably fix it. Trying to drive it over to get the work done could ruin your new clutch.
    You do know to replace the throw-out bearing and clutch position sensor at the same time, correct? Many pros like to replace the pilot bearing, too.
  21. cascam330
    cascam330 Rookie
    Mar 29, 2015
    4
    Ok. Uh the cost of sd3 is 25k USD?
    Using sd3 is it possible to adjust the shifting points and shifting timings?
  22. chenglo1
    chenglo1 Formula Junior
    Jun 23, 2012
    343
    Midwest
    Cheng
    yes. and the license expires too. totally not worth it to own unless u run a business that knows when and how to use it.
