Physical key without electronics is very inexpensive from China.. sub $15 each. https://www.aliexpress.com/item/KEYECU-for-Ferrari-F430-2005-2006-2007-2008-2009-Replacement-Remote-Car-Key-Shell-Case-Fob/32960444235.html?ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_10890_319_10546_10059_10884_317_10548_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536_10902,searchweb201603_57,ppcSwitch_0&algo_expid=d405ba94-91d0-4d4c-b0b8-37798326f7bf-3&algo_pvid=d405ba94-91d0-4d4c-b0b8-37798326f7bf&transAbTest=ae803_5 Even with electronics (unpaired) its still sub $100...
And for sub $20.. pke (bluetooth based automated keyless entry from your phone)... You can teach it to open as you get close to the car and lock as you go away... Ofcourse you can still use your key if smart phone battery runs out.. https://www.aliexpress.com/item/Auto-Keyless-Entry-Central-Locking-unlock-From-Phone-Push-Button-Lgnition-Trunk-SmartPhone-PKE-Control-Car/32976121762.html?ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_10890_319_10546_10059_10884_317_10548_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536_10902,searchweb201603_57,ppcSwitch_0&algo_expid=4500d381-8279-46c9-969b-866dad04c4a7-5&algo_pvid=4500d381-8279-46c9-969b-866dad04c4a7&transAbTest=ae803_5
What’s your ETA on the Swiss Army knife! I’ve been anxiously waiting, seems like you’re in final stages!
It's fully working by re-flashing ECUs out of the car (ie manually at this stage) and now I'm doing the obd reflash work. Since this is all part time best effort (not my day job!) I'm doing it in spare time so progress is variable. I am ofcourse making progress it's just a slow burn in the background. If you need immobilizer delete urgently due to hardware failure and costs spiralling out of control pm me and I can help ... Failing that I will need some more time. However yes it's going well!
This Means a lot to me coming from one of the most respected Ferrari techs in the entire USA.. Thank you, this was never about the money as other work could lead to much better return on time invested but to give something back... I am hoping it will benefit a lot of owners for many years to come...
This is so good to read! The immobilizer is one of the annoying issues with my 360. Hate having to push the alarm fob after 2mins or so if I leave the car unlocked. I would also love to have the unit on my my F430 deleted. Sent from my iPhone using FerrariChat
Thank you 360trev! While I am a new owner and bought my 360 with only one black key fob, I am rapidly becoming aware of the potential issues withe immobilizer and would like to be proactive in maintaining my car in good shape. I assume once you make these bypass units readily available, it will be easier to install a remote start and full functioning alarm system? I would like "modernize" the car a slight bit more. I think I have been spoiled by my modern cars and find myself needing more comforts the more I drive the car. Thanks again.
hi can your give more information. i had f430 immobilizer problme. i need delete immobilizer thank you komang
Nothing to update, fully 100% working on all F430s and 430 Scuderia, 16M, etc. Only 430 series not yet verified is a 430 Challenge car. Currently working on a solution to use obd to do it but it's a little way off so right now the fastest way is to send ecus to one of my US affiliates. Pm me. Also got 100% verified cat efficiency fix done for 430s too. Regards Trev
I am still expecting your reply on diagnosing wiring via whats app. You promised to reply on the day, but it has been a week, that I still have not heard anything from you sir.
I would like to remove the immobilizer from my F430 too. Please contact me at [email protected] Thanks in advance.
I am keen to remove the immobiliser on my 360. I am afraid my master remote key got corroded by battery acid and i'm now stranded with a car parked on my driveway. My email is [email protected] Thanks in advance buddy.
Let me tell you guys, there are 2 types of immobilizers in these cars.... ones that are failing or failed and ones that are going to fail. My car was one of the first to have issues. Probably because of the hot climate and some track work. It gave a plethora of peculiar starting and not starting issues. It was baffling. At the time, nobody had even heard of the symptoms I would describe. Half the techs thought I was crazy. Of course the dealer solution is new immobilizer and ECUs for $12K, with no promise of the crappy system failing again (if that was even the problem). Trev came out of nowhere to help find a solution, and I can't thank him enough. But above the elimination of that pesky immo, Trev has become a great friend. I've been able to ditch the immo completely and the car starts every time, runs flawlessly and the car doesn't need to be on a tender. It's brilliant!
Is it only me or does anybody else think, these desperate attempts to get a tool for deleting Ferrari Immobilizers with odd email addresses by users with 1 post (except for the last one) are a little bit scary?
I wonder if these forum would help for immo delete. I have been in this tread for a while, nothing that I see for solution to bypass immo for f430.
did you try stepping on the brake pedal with all your weight? it cld be the sensor needs to be replaced
