News
Ferrari F430- Weird F1 issue
Discussion in '360/430' started by vv23, Jul 30, 2020.
  1. vv23
    vv23 Karting
    Jan 8, 2009
    179
    Edmonton, Alberta
    V V
    Hey guys,
    Got an odd issue with my transmission. I have had my accumulator replaced due to it crapping out. Car drove normal after.
    After an hour of driving it started to fall out of gear during some shifts, so I got the entire system re-bled.
    Now I am getting an Ediff light when I start driving (and after an hour of driving it falls out of gear again).
    Any idea what the isssue could be?
  3. mike32
    mike32 F1 Rookie
    May 13, 2016
    3,187
    Uk
    Any chance the pump is a bit worn, as the oil gets hot it is having a problem maintaining the pressure.
    Pump motor on its way out or fuse or relay . You get an hour before problems so something heating up ?
  4. vv23
    vv23 Karting
    Jan 8, 2009
    179
    Edmonton, Alberta
    V V
    Hmm could be.
    I was thinking air in the system so got the entire system rebled. There is absolutely no air in it now.
    Ediff issue happens right away. The falling out of gear happens within an hour.
  5. flash32
    flash32 Formula 3
    Aug 22, 2008
    2,197
    Central NJ
    Dominick
    Can you get codes pulled ?
    Can be any of the following
    Faulty ediff solenoid
    Loose screws on actuator
    Bad / weak pump
    Bad actuator
    Potentiometers
    How many miles ?
    If you have a good diag tool ..getting some print outs of pressures while driving (graph) can help
    Sent from my moto g(7) using Tapatalk
