Ferrari F8 Tributo | Page 161 | FerrariChat
Ferrari F8 Tributo
Discussion in '458 Italia/488/F8' started by Ferrari 308 GTB, Feb 28, 2019.
  1. Art138
    Art138 Formula 3
    Nov 22, 2007
    1,534
    Ft. Lauderdale
    I read in other posts that pulling the vacuum at the valves would signal a code. Do you mean the dealer can reprogram the ecu to tolerate the vales open all the time? On my Scud I just pulled the tubes myself from the valves with no issue.
  2. buddyg
    buddyg F1 Veteran
    6,298
    Naples, FL
    Buddy
    Thanks now take a video winding it out and through the gears!
  3. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,879
    France
    Indeed they are the same size as the non-carbon ones - I really thought they had been extended. The Geneva showcar with the carbon options had extended paddles, as depicted in Ferrari's media gallery. It's a real shame if they deliver the customers cars with the short carbon paddles.
  4. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    Tech at the dealer advised it is a simple task which they will undertake whe then car arrives. It does not involve any ECU reprogramming.
  5. Drson
    Drson Karting
    Mar 18, 2018
    152
    Southeast
    John Galt
    I inquired about having the valves opened/pinned open on the F8 and my dealer told me this is not advisable because it can cause engine damage, check engine lights and performance issues......that being said I had this done on my 2015 458 and never had any issues.....so what is the real answer? Maybe someone can enlighten me...thanks in advance
  6. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,645
    AUSTRALIA
    ANGELO
    Coincid will definitely confirm when he gets his F8 :)
    Coincid and Drson like this.
  7. OSUferrari
    OSUferrari Formula Junior
    Dec 13, 2015
    631
    Denver CO
    Mine will be here next week. My dealer said same. They can not open valves in F8 (or Portofino). . Ferrari made a change and these are electronic and won’t allow it (he did say the hope is someone will figure it out). Fingers crossed
  8. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,435
    Tampa FL
    Do the valves open up around 3k rpm depending on throttle like they do on the 488?
    Seems odd about engine damage as the valves just control sound at low rpm by diverting exhaust to muffler or not. There is gas pressure difference but still not really much and just sound difference.
  9. Jo Sta7
    Jo Sta7 F1 Veteran
    5,912
    Scottsdale/Pittsburgh
    Jon
    Owners better post up reviews when they receive the cars.
  10. cpiguy
    cpiguy Formula 3
    2,137
    Westlake Village, CA
    Arnie Friedman
    Yeah, I heard the same thing. If that’s the case we should be able to get the remote valve control I had on my 488’s.
  11. OSUferrari
    Dec 13, 2015
    631
    Denver CO
    That will not work. I had that on my 458. Will not work based on my previous post
  12. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    #4013 Shadowfax, Mar 26, 2020
    Using a valve controller or pegging the valves permanently open on this car is no longer an option due to the pressure sensors pre and post which ensure proper operation of the GPF. Any slight change in pulse or back-pressure and it goes into limp. It's apparently very very sensitive. The pressure in the pipe between the GPF is maintained by the valves. Keep in mind the valves are post the GPF which is precisely why they now have a sensor there now so if the valves don't work properly the ECU can detect it and shut the system down. The valves are also electronic so they can open the valves up incrementally depending upon what the ECU reads as necessary to maintain the correct pressure within the pipe. A VTG turbo works in a similar way being electronically actuated where the vanes move incrementally, controlled by the ECU and the various associated sensors.
    On the Pista and 488 the valves are vacuum controlled and are either fully open or closed. Pista has the sensor in the plenum and can detect the change in pulse and pressure once the cats are removed. I'm told Pista's system is much more sensitive than 488 but still nowhere near as sensitive as F8's systems. This is the engine advancements claimed by F8. The correct operation of the GPF has been made integral to the proper running of the entire engine, Screw with it and the engine won't run and screwing around with the opening of the valves will have a direct impact.
    My tech assures the F8's intake and exhaust system is fail safe and the only way around the ECU and sensors will be to remap it. For those who believe otherwise let "the horse" be with them.
    Astrid.Didier, Avia11 and mdrums like this.
  13. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,435
    Tampa FL
    Thanks Shadowfax...well that sucks because the sound of the F8’s I have heard is very bland.
    Do the USA cars get a particulate filter?
    Shadowfax likes this.
  14. Shadowfax
    Shadowfax F1 Rookie
    4,066
    Australia
    #4015 Shadowfax, Mar 26, 2020
    Seems none are immune to the GPF. Also agree F8's sound is nothing particularly memorable that's for 100% certain, inside or out. But it's the way of the future they say. But re the info that's what my head tech reports and, he's never been wrong on anything so far and, he's top dog out here....one of those guys who lives and breathes the product with a passion (for the past 31 years). But for the sake of others here I truly hope he's wrong on this. I really do. I think someone needs to disconnect their valves and report exactly what happens. And desirably do it in their workshop or in close proximity to.
    elmadi, mdrums and of2worlds like this.
  15. Jo Sta7
    Jo Sta7 F1 Veteran
    5,912
    Jon
    I always find cars sound more important in theory and more annoying in practice. A loud car drives by, it rarely ever sounds good. Even most super cars sound, well just loud.
    Boomhauer, tfazio, Drson and 2 others like this.
  16. buddyg
    buddyg F1 Veteran
    6,298
    Naples, FL
    Buddy
    AND VIDEOS INSIDE AND OUT! STILL AND DRIVING!
  17. Astrid.Didier
    Astrid.Didier Formula Junior
    Nov 8, 2019
    672
  18. Jo Sta7
    Jo Sta7 F1 Veteran
    5,912
    Jon
    He didn’t seem as wowed as by the Pista, which makes sense.
  19. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    His driving reviews, if one can refer to them as such, consist of a gaggle of chuckles interspersed with a dollop of “wows”. His trips on city streets, often in traffic, are hardly the venue to make a determination of the technical and subjective attributes of a super car.
  20. ferrarifanatic25
    ferrarifanatic25 Formula Junior
    Apr 9, 2009
    889
    OC
    It seems none are immune to crazy euro policies... nor East Asian viruses.
    Sorry, I had to (flame suit engaged).
    Jo Sta7 likes this.
  21. RichardCH
    RichardCH F1 Rookie
    4,661
    Seems to be alot of hard plastics in the interior for this money !
  22. jumpinjohn
    jumpinjohn F1 Veteran
    7,563
    Texas
    Those are special Italian Ferrari fine crafted interior pieces. Categorically different from “hard plastics” don’t you know!
    elmadi likes this.
