Ferrari FF Electrical System Failure | FerrariChat
Discussion in 'FF/Lusso' started by StephenB, May 13, 2016.
  1. StephenB
    StephenB Formula Junior
    Feb 12, 2007
    304
    S Florida
    Stephen Bruno
    I am glad I took these videos as hopefully it will help in diagnosing the issue. Naturally the car is at the dealer and while there were tons of error codes, it is not doing it now and Italy does not know what to replace.
    Here are the links..
    Initial failure, manetto failure message, windows dropping a half inch and then going back up and the interior light coming on and off.
    https://youtu.be/03yuf7vvkNA
    Complete cluster failure part one
    https://youtu.be/e3tELohJtAs
    Complete cluster failure part two
    https://youtu.be/g8cZWv8EXNs
  2. Brian L
    Brian L Formula 3
    Jun 17, 2015
    1,943
    Los Angeles
    Brian
    ManneTINO = little lever
    What's the year and mileage?
    Were you driving regularly and using a tender every two weeks of non driving?
    How long have you had the FF?
    Did you buy the car from some joker for cheap, or from a dealer with good books/history?
  3. StephenB
    Feb 12, 2007
    304
    S Florida
    Stephen Bruno
    It is a 2105 bought new, it is my daily driver has 6k on it. My second FF the first was a 2014 that I drove for 12k miles.
  4. ttforcefed
    ttforcefed F1 World Champ
    19,256
    sometimes the car just needs to be rebooted - like a computer
  5. StephenB
    Feb 12, 2007
    304
    S Florida
    Stephen Bruno
    I tried that. Disconnected the battery for five minutes. Didn't work.
  6. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    pure speculation on my part, since the error codes are probably the breadcrumbs...
    I'll assume the battery is good, and since this occurred while driving, it wasn't a low voltage problem (Assuming the alternator is producing clean power). If it was, you'd probably have different symptoms
    Given the cluster/windows/et al, I'm going guess
    1) bad connection to one of the (many) chassis ECU's, or there is a sensor/microswitch somewhere with an intermittent ground fault or bad connection (Eg. the windows are dropped when the door lever microswitches are activated)
    2) IF it's just a SW glitch, and a hard reset didn't work (battery disconnect), the dealer can reload software
    3) as a an attempt at empathy, our 2015 once flashed every alarm, bell and whistle. Full, good battery. Our dealer Master Tech (who is a wizard) eventually deduced that there was a bad rain sensor (in the rearview mirror). That was causing faults, popped a fuse, et al. I suspect the radar installer had done something, but who knows. Bottom line, there was nothing pointing to the rain sensor, but the tech had to sort of eliminate it down system by system. The CAN network in these cars is very complex, and only mildly fault tolerant (which, BTW, is the same with most high-end cars)
    Please keep us posted.
  7. Caeruleus11
    Caeruleus11 F1 World Champ
    11,620
    It can be anything. Thats the problem with all these advanced electronics. This reminds me of when I had a parking sensor go bad on my 599. All of a sudden everything failed... Got to be seen by your dealer... Sorry. Downside of high tech.
  8. StephenB
    Feb 12, 2007
    304
    S Florida
    Stephen Bruno
    Or nothing! The car was in for over a week, they found many error codes in the computer, reset and guess what, did not do it again. I am driving it waiting for it to happen again.
  9. ttforcefed
    19,256
    Lol gotta love it - maybe it took a special super secret version of cntrl alt delete!
  10. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    My hunch is a bad battery especially as there were loads of error codes.
    Even if it appears good a bad cell can limit the current delivering capability (high internal resistance) of the battery which will cause voltage drops and can then causes errors.
    If you have the factory battery (FIAMM?) then well worth changing it in my experience. Even from new the the factory batteries can often have issues especially if they have been allowed to go completely flat during transportation etc.
  11. Brian L
    Brian L Formula 3
    Jun 17, 2015
    1,943
    Los Angeles
    Brian
    Service Mgr here says bad battery cell, or not driving the car enough/no tender, main cause of most electrical gremlins. Drive more, less problems.
  12. Caeruleus11
    11,620
    I guess she just wanted some extra TLC... Suggestion- have them hook you up with a better tender like the 7002 Ctek and make sure to plug in when you know you won't drive it the next day...
  13. otakki
    otakki Formula 3
    1,634
    It's too bad the oem battery is not up to par. What battery brand and model is a good aftermarket alternative?
  14. sesto22
    sesto22 Rookie
    Jul 19, 2016
    22
    Electrical system failure, Manettino failure and TPMS failure. All dash lights are on. Originally had the wrong battery installed, have since switched to an AGM Duracell 49/H8. No change, though. Car will not start. Tried to start, but won’t fire/turn-over. I thk that is the computer telling it to not deliver fuel.
    How do I reboot the whole system?
  15. TurboDoc
    TurboDoc Rookie
    Apr 8, 2018
    34
    BKB
    I am currently having the identical “electrical system failure” to the original thread. However, it only occurs when the car sits outside for hours below 30F. The battery is brand new and dealer installed less than 6 months ago. I daily drive the car at least 20 minutes each way and use the tender religiously.
    The car starts fine and after warming up for a few minutes the electrical failures resolve one by one.
    I’m under warranty but so far haven’t sent it the 250 miles to the dealer.
  16. ScottS
    ScottS F1 Rookie
    2,937
    Winter Park
    Scott S
    Had similar issue with cold weather and not driving daily and no tender. Changed battery. There was also lead issue which contributed.
    Both resolved with lead change and new battery.
    uberwag likes this.
  17. otakki
    otakki Formula 3
    1,634
    What's "lead issue" and "lead change?"
  18. uberwag
    uberwag Karting
    123
    Winter Park, FL
    Preston
    Repinging this to get some feedback from the forum...
    Getting a persistent "Electrical System Failure - see dealer" warning for a while. Battery good and fresh (Interstate, a year and a half old), lives on a tender, no issues with driving it or other warning messages, and messages goes away after a few restarts/car getting warm. I know a number of people have had this issue and there have been a couple of different experiences with "fixing" it (and how long that fix actually lasts... for example, I have Scott's car and even with the above it is still happening) - would love feedback on what updated thinking there is now on this!
  19. ttforcefed
    19,256
    Replace with a new interstate and the assess
  20. uberwag
    uberwag Karting
    123
    Winter Park, FL
    Preston
    Image Unavailable, Please Login This is the battery, dated 1/2020 if I remember correctly. I bought a new battery in August to do just as you recommended (I read that on the forums in prior search), so brought new battery home to install...and realized that I already had a fresh one once I got it out of the car. Pain in the ass. Same model, operating even higher than rated when I took it back to be tested before returning the new one and reinstalling.
  21. ttforcefed
    19,256
    It cld have a bad cell and still tests ok
  22. uberwag
    uberwag Karting
    123
    Winter Park, FL
    Preston
    Anyone else have other experiences beyond battery for this, or universally this was always resolved with battery change?
    As far as behavior, it doesn’t happen when the car is warm and after a few starts it stops all together. Then, will come back after sitting.
    Any other battery options beyond the interstate battery that most use?
  23. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Santa Barbara County
    Sam
    I have my car on a tender and get the same warning when I start it. If I drive it a few miles and restart, it goes away
    Bonovox09 and vraa like this.
  24. ttforcefed
    19,256
    Have u tried using a different tender?
  25. Way2fast
    Way2fast Formula 3
    May 24, 2006
    2,211
    Sam
    Ever since the idiots that took 8 weeks to install my Pioneer head unit installed new amps, it seems to drain the car while sitting. I gave up trying to solve it and just plug it in. It is the Ferrari tender
