Ferrari Fuel hose fittings. What size or type? | FerrariChat
Discussion in 'Technical Q&A' started by tf308, Nov 29, 2021.
  1. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Does anyone know the fitting size for the fuel hoses that connect from the filter to the fuel rail?
    I would like to make one just to test the fuel pressure…nothing permanent.
  2. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    PS..here is a pic from mine on the 512tr.
    I believe the threads are 14mm 1.5 but I am not sure about the center flare.
    I thought Ferrari did a recall update on mine….but both ends use aluminum nuts.
  3. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    PS…I am asking because I wish to make a temporary line to pipe a fuel pressure guage to test my regulators.
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,279
    Lyon (FR)
    R. Emin
    The hose were supplied by cohline. That's an old fashioned company with paper catalogue. Their UK distributor (Cohpro) is helpfull, quick, courteous and cheap.
  5. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Thank you so much. I believe I found a supplier for fittings. I will report back when I have more.
  6. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    491
    Victoria, B.C, Can.
    John Glen Wesanko
    Thanks very much Raemin, I have been looking for these 348 fuel line fittings for ages. Do you have any information regarding the ID of the orriginal ss braided fuel lines ?
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    2,279
    Lyon (FR)
    R. Emin
    I have no first hand experience on the 328 or 348... You could drop cohpro an email. He will probably advise against the original braided hose as they do not tolerate ethanol, however he can provide alternate cohline references. So better to ask the expert directly.
    Cohline catalogs can be downloaded here : https://www.cohpro.com/cohline-catalogue
  8. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    781
    Treasure Coast Florida
    MATT
    They are actually referred to as inverted flare fittings. And specifically 14x1.5 mm. You can buy various fittings and adapters on eBay. Don't
    bother with auto stores.
  9. John Glen
    Dec 30, 2009
    491
    Victoria, B.C, Can.
    John Glen Wesanko
    I'm looking for the 180 degree end fittings that attatch to the fuel rails. Orriginal are blue annodised aluminum but I'd rather ss if available. Any sources ?
  10. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    I ordered fittings from BelMetric…
    The interior diameter is 6mm on the 512tr.
    I will keep you posted. They should arrive tomorrow
  11. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    This is everything you need. I got these from Matt at BelMetric in the USA. I tested the fit and it works.
    The part numbers are in the picture.
  12. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
  13. paul01
    paul01 Karting
    Jul 31, 2011
    104
    Hi,
    i want a fuel hose for 348 as a spare part to take with me in the car when driving. Only fore safety and to drive back home
    in case of a problem.
    A straight hose is sufficiant.
    But i am not sure if i understand above "14x1.5". Is it really metric for 348: M14x1.5 ?
    Regards
    Paul
  14. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,205
    Georgia
    Wade Williams
    There are two different sizes on Ferrari fuel rails. 14 x 1.5 inverted flare and 12 x 1.5 inverted flare.
    You can measure the male part and it will be 14mm or 12mm. Then you will know what you need.
    I believed the rail size is 14mm and the regulator size is 12mm.
    paul01 likes this.
  15. paul01
    paul01 Karting
    Jul 31, 2011
    104
    Ferrari Tech,
    ok. I am able to measure it when it is disconnected.
    "14 x 1.5 inverted flare and 12 x 1.5 inverted flare" is ok for me. I order both. These are standard sizes here in Germany.
    Thank you
    Paul
    Ferrari Tech likes this.
