Doubtful that vacuum on the outer body would do much. A proper tool for the piston will grip pretty well. When I tried prior, I just looked for something in the shop that would work. I was too lazy then to make something We don't have a manual lathe (should get one). But I will have one of my guys knock this out during the week between jobs - we have a job ending in a couple days. I do have a vacuum generator so it should work well
Think about it. Dave said the piston area is 0.14 sq inches. So the max pulling force a vacuum could generate is 2 lbs. Is that enough?
The inner piston area is .14, the outer diameter is larger so the area will be a bit larger. If I get a chance today I will use some weight to determine the load needed. It's such an easy part to make that it's worth a try. Might take my guy Paul 1/2 hour to make
I was replying to you last post John but it vanished I have a vacuum generator. Yep, already looked to see it I had tubing that would fit, but I don't I just checked the force with some blocks - it's approx 6 lbs. But, that is also on clean parts. So, add some oil friction and possible grime and yeah, it's probably not a safe bet so back to the sure method of a collet
Vacuum applied to the outer body would pull a vacuum on both sides of the piston through the leakage gap. Plus, you would have to plug the oil supply hole or you would just suck air. So far the best idea were a pair of pliers designed to grip the piston, or just banging it on a board.
FBB's pliers idea was good for sure. I looked yesterday at parallel jaw pliers and possibly machining the jaws. It's a good idea and I'm happy to admit it. But, I feel better about the secure nature of a collet. As to banging them on board - look that the damage to the edge (probably not a huge deal). I'll send you my 50 (40 + 10 spares) and you can bang away, John
Valve stem seal pliers? https://www.cromwell.co.uk/shop/automotive/valve-adjustment-and-grinding-tools/extra-long-valve-seal-ring-pliers/p/KEN5032690K?utm_campaign=pla+-+&utm_source=google&utm_medium=shopping-pla&utm_keyword=KEN5032690K&istCompanyId=6aa6787b-063e-4414-802d-129f235df603&istItemId=aqrxmxtwp&istBid=tztx
Hey Paul, They don't list the ID that I can find and they are not smooth - but thank you very much for this coz I did not know these exist and I need a set for my seals
Dave are there any pliers made that can accept a collet? So rather than threading it just draws it in to compress?
Not that I know of but see these clamps - they are linear pull some a concept like this could be used. Straight Line Action Clamps - Push & Pull Clamps | DESTACO As far as the threads, that's a very easy machining operation and I don't think more that a turn or so will be needed.
Pretty sure they come in a variety of stem seal diameter sizes, find one oversize to your needs and line it with some thin rubber, Bobs your uncle.
The gripping area (amount of piston protrusion) is very small, about 0.08". The gripper needs to be precise.
Noticed the part number for these is 149750 for 355 and changed to 195017 for the 360. Would be interesting to compare the difference.
Hey Jim, They must be equivalent and perhaps a superseded part number. Eurospares lists 149750 for 355 Ferrari 355 (2.7 Motronic) - Timing - Tappets and Shields: Page 005 | Order Online Eurospares Algar lists 195017 for 355 as well as 360 https://algarferrari.com/store/parts/6-8-cylinder/355-group/f355-m2-7/table-5
