Ferrari makes engine head with non-aligned bore holes | FerrariChat
Discussion in 'Technical Q&A' started by bigbadbill, Jul 31, 2016.
  1. bigbadbill
    bigbadbill Rookie
    Aug 23, 2015
    14
    My timing belt tensioner broke on my 348 spider and the dealer has had the car for 4 months. They were ready to reassemble using aftermarket valves, etc. when I got a phone call saying that the valves don't fit!
    Here is there exact explanation from an email from the dealer:
    "To try to explain this, the valve guides go into the top of the head. the valves go into the head from the bottom. the guides are shafts the valves ride in to ensure they have a perfectly straight, linear motion. with the new perfectly straight guides the valve are basically sitting at an angle. they are not sitting flush with the valve seat at the bottom of the head. what conclusion we have come to is that the bores in the head that the guides mount into were not aligned perfectly to start with. to compensate for this when the heads were first built they used guides with a slightly off center bore. with this the valves would sit properly on the valve seat and seal. we are trying to get the correct "off center" bored guides to allow the exhaust valves to sit perfectly and seal on their seats"
    Sure makes it sound like Ferrari sold me an engine head where the bores were not aligned perfectly. My question is, is this something anyone has heard of before. I bought my 94 Spider from the same dealer and it has never been service anywhere else. It is at the dealer for an engine rebuild. I sure need some help. Any help would be appreciated.
  2. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    First of all, welcome to FChat.
    Secondly, sorry about your belt breakage. I and a few others here have been trying to get a real world sense of when and why the belts break. Could you provide more info about your incident: age and mileage of belt, circumstances under which it broke, how the car has been driven and maintained over the life of this belt, etc?
    As to the issue with the guides, that’s a very strange indeed. They seem to be saying that the bores in the head that hold the guides were not machined perfectly perpendicularly to the valve seats. I’ve seen seats that were not concentric with the guides but I don’t recall seeing what they’re describing. Are they certain that the head was not distorted when the valves bent?
    If the problem is indeed that the bores in the head for the valve guides were drilled at the wrong angle, and assuming that the seats seem to be installed correctly, I can think of a couple of potential solutions. One would be to have “blank”, unbored guides made to the correct spec (SBI in CA ought to be able to help you there), install those (which may prove to be a bit of a trick since guide drivers have mandrels that fit inside the bore of the guide), and then bore them in situ by indexing off of the valve seats. The downside there is that this time consuming boring process would have to be repeated any time the guides need changing (which should not be often). The upside is that you get as many chances as you want/need to do the job correctly and the original guide thickness is maintained, so you don’t have to worry about cutting into cooling jackets and heat transfer should be roughly the same as the original design. That’s likely what the factory did, based on the quoted description of the problem. Note that sourcing guides with holes already offset or angled would not be an option because there would be no way to index them properly during installation.
    Another option would be to remove the guides and correct their bores by indexing off of the valve seats and then drilling the guide bores in the head oversized. You’d then have custom guides made to fit the new, larger bores. The upside there is that the guides would be easier to install and if they ever needed replacement it’d be simple enough to have new custom guides made. The downside is that you screw up the head if you goof the cut badly and there may be space considerations, although presumably the angle is not so far off that it would require that much bigger of a bore to get the guides aligned properly.
    A more expedient solution would be to install new valve seats and cut them based on the existing valve guide angles, but that strikes me as a poor choice because it would not correct the relationship of the valve tip to the lifter bucket.
    Considering the expense and risks involved in correcting this problem it may well be better to just source a used head or heads (check eBay and negotiate, negotiate, negotiate!). Incidentally, are all of the guides on both heads the same or is it only one row of guides on one head?
    Best of luck and please follow up as you learn more. This is a new one on me… at least as far as my poor memory can recall.
  3. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Welcome to the forum mate.
    A Ferrari engine with the bores not machined correctly from the factory??? I find this very hard to believe.
    I have never heard of this before and why didn't this problem happen 20 years ago??
    After all, this engine is 20+ years old now so this would have happened in the past.
    A little more information in regards to the car would be much appreciated thanks mate.
    I will take a little guess here and say your 348 just had a major service from this dealer, they messed it up and now the cam belt has broken causing major damage to the engine.
    And now the mechanic has made a ridiculous claim like this to try and cover his ass!
    This claim from the mechanic reminds a little of this mechanic's claims in another thread with a 348 cam belt failure.
  4. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Sounds to me like the valve seats have not been installed correctly. Maybe some swarf under one side.
    Pete
  5. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    #5 Dave rocks, Aug 1, 2016
    I'd bet the original guide bores where concentric with the seat bores (within part print specifications) You need a machine shop that knows what they are doing. The guides need to come out and then they can inspect the guide bore with relationship to the seat. If stuff is screwed up, you might need new seats and full machining. I'm Pretty certain Ferrari used Comau machines and they are amazing for doing this work. We had a Comau line when I was at GM and it was some great equipment.
  6. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    It's not that uncommon to find machining oddities in the pre-1970 engines. I have a 60's Ferrari engine here with similar issues as well as slightly different valve angles, head to head. With that said, it is uncommon to see issues, as described, in more modern engines without external (self-induced) forces being involved.
    With that said, ///Mike offers some viable solutions to the problem.
  8. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    Seems like we're on the same page, David. How are you addressing the issue in the '60's engine you mentioned?
  9. bigbadbill
    bigbadbill Rookie
    Aug 23, 2015
    14
    I thank everyone for the replys. Back details. Bought 1994 348 spider directly from same dealer working on it today. New. I guess about 100 miles. Last service was to same dealer for routine maintenance about 2 years ago. Said belt was fine. No need to change. I was taking car out for bi-weekly or so drive, engine light(1-4, I believe) came on. Car has 21,000 miles by the way. Stopped the car. Cut if off. Headed back home. The engine light came back on. Still same power no noises. Thought may catalytic converters? Got about a mile from home heard a muted thump and felt a loss of power. Turned into grocery store lot and called hauler, as engine lost a lot of power. Never heard any other noises. Dealer says the belt did not break; that it was the tensioner pulley?, I believe he said, that broke. Ruined all valves, etc. Found aftermarket valves but cost to fix was to be approximately $34,000.00 and now this problem. History is basic. Routine maintenance. Dealer has verified that they blame Ferrari for this new problem. I am wondering could they be thinking this is a f119g engine and not a f119j engine that was unique to the 348 spider? I would think a dealer would check this out/know this though right? Again thank you all so much for your time and knowledge.
  10. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,734
    Tech installed the valve guides improperly.
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,241
    CT
    John Kreskovsky
    Let me be direct. BS! Seats are ground with a tool/machine that is aligned with the axis of the guide bore so that the seat is perpendicular to the axis of guide bore and the valves seals correctly. I agree with Dave Rocks. Someone didn't know what they were doing.
  12. johnk...
    Jun 11, 2004
    11,241
    CT
    John Kreskovsky
    #12 johnk..., Aug 1, 2016
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    According to his similar post in the 355 section, the guides have not been replaced.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #14 Dave rocks, Aug 1, 2016
    Correct, John. Even before the guides or seats are pressed in the head, the guide and seat bores are done from the same side and typically with the same stepped (combination) tool that cuts both at the same time.
  15. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,775
    Lake Villa IL
    Agreed^^. Something strange going on here.
  16. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,014
    PA
    Kevin
    Agreed. An authorized dealer skipped the timing belt service because the belt looked fine? Doesn't make sense.
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Dont believe it, how on earth could you fit off centre guides in the original head, you would never get them in the right place so the valve sat correctly on the seat. Assuming you suspect the guides you need to take 1 out and turn a bar on a lathe which just fits, then clock the outer diameter to see if it runs off centre. These guides would have been chilled and pressed in. Why not fit a new set of guides that run true, then replace the valve seats and cut in situ to suit the new valves- you will get in right trouble trying to adjust the guides to the valves.
    When the head was originally made they would have used the same centre to machine the head for the valve guides and the seats so this idea of off set does not ring true with me.
  18. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    I'm smelling some dealer-generated, unadulterated Bull**** here.
  19. johnk...
    Jun 11, 2004
    11,241
    CT
    John Kreskovsky
    Also, after market parts? Not at a Ferrari dealer that I have dealt with. They only use OEM parts.
  20. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Anybody getting the idea of waffle from the workshop here. It will be interesting to see how they fix this one, tubes of silicon next !!!
  21. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    And Duct tape!
  22. INRange
    INRange F1 World Champ
    12,589
    Virginia/Florida/Caymans
    JD
    So, he can show you the original "factory offset guides" he removed so that you can see for yourself?
    If they know what they are doing....the sequence is to install the guides and then machine/replace the seats.
    I have seen improperly machined replacement guides. I'm curious if all the valves have the seating problem or only a few.
  23. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    The only way you would have off set in the guides would be if they were oval with wear. I think i would be going for a set of new guides, then see how true the guides were to the seats. You can get those air driven seat cutters which use a centering pin fitted in the valve guide. We used them in big marine diesels but we used to cut the seat with 0.7 degree extra angle so the valve only touched at the top- you run the engine on light load for a short time and the valve makes it own seal.
  24. bigbadbill
    bigbadbill Rookie
    Aug 23, 2015
    14
    Yes, after market parts. I know. I agree. That's what I thought. But they told me the Ferrari parts prices and the aftermarket prices and told me their own mechanic had used the aftermarket valves,etc. and they turned out just fine. The ferrari parts prices sent the cost over $50,000.00 in total. My God. I could buy a running one for that. I am not an expert as I am sure you can tell. I have to rely on what the dealership tells me. And yes I was told by the service manager of the dealership that the belt "looked" fine when it was up there about 2 years ago. I don't have my paperwork as they have my car but it was replaced I estimate about 5 years ago? I am having to go on memory. I was told the belt did not break. The metal tensioner or pulley broke that holds the belt tight. That was what caused the damage.
  25. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    That tooling is beautiful!!!
