Ferrari makes engine head with non-aligned bore holes | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by bigbadbill, Jul 31, 2016.
  1. bigbadbill
    bigbadbill Rookie
    Aug 23, 2015
    14
    Gentlemen, thank you for all your wonderful answers. I knew this felt wrong. Both the dealer and I are neck deep in **** apparently. I have a car that is really broken and they have a car that is taken apart and won't go back together short of a whole lot more work. I will up date you as soon as the dealer tells me what they propose. I am just waiting; as I have been for the last 4 months. I love this car but I don't think I can afford to invest $40,000+ in it, especially as the problem it now was not of my doing. I can assume someone seriously messed up somewhere. So is the solution to find a machinist who can fix the problem, hopefully, and pay for the extra work or not pay for the extra work, or even get some type of credit because my engine got messed up by the prior machinist, just forget this engine and look for another one, or ?? What would you do?
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Get the heads to a proper machine shop who can I inspect them and go from their. Your location would be helpful.
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Offset valve guides
    They go with the offset wheel lugs so they can fit many different models with one sku
  4. JCR
    JCR F1 World Champ
    11,033
    H-Town, Tejas
    Is the dealer actually doing the machine work? Most farm this out to shops that have the proper equipment like a Serdi or Newen.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,995
    Isle of man- uk
    Get a set of new guides so you start with something you know is right and go from there- these are a common part, ie mondial, tr etc. They seem to come in standard and 0.2 mm overside. Eurospares in UK are showing both in stock. You are probably going to have to chill them to get them fitted. Once you have these fitted you can see if they can machine the original seats to this known centre. Otherwise you will then need to fit new seats. There really is not another practical way to go, as if you use standard bits you know you will be able to use the ferrari shim range
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    What he needs to have done by a qualified machine shop is to have the guide bores (of the head, not the guides) checked for concentricity to the current seats. That is the starting place. A good machine shop will be able to inspect properly and will know how to resolve this.
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Awesome^ :D. Let's just make valves with a double cardan joint. Fixed!
  8. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    STOP THE INSANITY!!! You're talking about spending $37-50k on a top end rebuild? Nearly the entire value of the car.... And have the work donr by a shop that apperently has no idea what is going on. You need to go box up your car and get it away from them NOW.
    You can get a good set of low mileage heads for around $4k pretty easy or a complete long block engine for $8k just drop it in and go.
  9. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    Sell me the car. I'll buy a good engine and put it in for under $10k. 348 engines are a dime a dozen. Then I'll sell off the good parts of the old motor and recover some cost. Everybody's happy!
    Where did the aftermarket valves come from? You bought the car new, when were new valves necessary before?
  10. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    ___________________________________________________
    +1
    something very odd with this dealer......take the car elsewhere.
  11. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1
    check out ebay for a motor.....
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    where are you Big Bill?
  13. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I'm in with just dropping either a used motor in our replacement heads. Either way is much less expensive. I'd also take it away from the shop that just did this work.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Guys, there is likely no reason to drop in another motor. Heads are rebuilt all the time - probably every day. A good machine shop needs to have a look and determine the issue. I'm confident without even seeing them (unless they have been hacked beyond belief) that they can be rebuilt.
  15. 430tdf
    430tdf Formula Junior
    Aug 7, 2008
    285
    Canada
    Brett
    Go find a good used motor and forget about rebuilding the broken one, just put in storage to sell with the car in the future.
    The car is just not worth enough to invest in rebuilding,
  16. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    I knew I could smell a rat!!
    Sorry to hear, but it sounds like the dealer made a boo-boo at the last major service and didn't replace the belt and tensioners like they should have.
    And now they made up this BS excuse to tell you! Give me a break!
    Again, sounds like the dealer/mechanic messed up and they are trying to pull the wool over your eyes with BS to make you pay for the damage done to you car.
    Cheaper to have a used engine fitted, but if you're not in a hurry take the car to a reputable Ferrari independent and have them repair the heads for you.
    I wish you all the best with it mate, please let us know how you go.
  17. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    It is a common guide installation error on this type head. I have seen it before and can fix it without major re machining. It's not just Ferrari issue either.
    And no, I am not giving away years of engine building knowledge, it's how I make money.
    I do all of the head work here at Ferrari of Atlanta in house in our basement. If you have a set that needs work, I am your guy. New, really old, any of them. I can make it right.
    I agree that at some point it may be a better choice to just put a used engine in it.
    Have not seen the heads on this one so it is a guess at this point.
  18. intrepidcva11
    intrepidcva11 F1 Rookie
    3,232
    Saratoga Springs NY
    Seth
    Wade, since you're performing very highly skilled work at FoA from whom I bought a 400i many years ago, I'm assuming you've done a tour at the factory. Is it conceivable to you that in the 1990s the engine shop at Maranello dealt with this problem thus? - "what conclusion we have come to is that the bores in the head that the guides mount into were not aligned perfectly to start with. to compensate for this when the heads were first built they used guides with a slightly off center bore?"
    Don't smell clean to me
  19. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Common? With all the 355s that have had guides replaced I haven't heard of anyone having such an issue.
  20. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    guy does this for a living and says it's "common" & "seen it before" what more do you need?
  21. Ferrari Tech
    Mar 5, 2010
    1,231
    Georgia
    Wade Williams
    355s don't have the issue this one has. It is common on older stuff.
  22. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    A previously unheard of problem is reported an one person states it common and you accept that blindly? I accept the guy is an "expert" but common means "occurring, found, or done often; prevalent". For me to accept this as a common problem I would not expect this to be the first time of hearing such after 30+ years of being around Ferraris. No need to say how he fixes it, no need to reveal trade secrets, but it wouldn't hurt to at least explain how it happens.
  23. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Wade, no problem. But we are talking about a 348 here. Is that older stuff? I mean, seems like you statement is out of context and therefore a little misleading.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    So you are saying the guides where not pressed into the guide bores in the head straight by Ferrari factory?
    If that is the case, are you saying the factory did no post guide installation machining of the guide or the valve seat?
