FERRARI part - Bosch equivalent | FerrariChat
Discussion in 'Technical Q&A' started by frogwo, Feb 10, 2007.
  1. frogwo
    frogwo Formula Junior
    Jan 15, 2005
    283
    Does any one know the Bosch part number for Ferrari part number 164369
    Turn signal relay.
    Thank you.
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Good 'ol Shemp, the Brotherhood encylopedia. :D
  4. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    I used the EP36 from Autozone until I could buy the $150.00 same Ferrari part.
    the EP36 works fine.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    Have you looked inside the relay yet?
    It is fairly typical for the solder joints on the PC board to crack, causing the relay to not work. You can pop the cover off of the relay and then look at the joints to see if there are any cracks where component pins connect to the board. Just solder up any cracks and it should work.
  6. tamf328
    Mar 9, 2005
    477
    excellent advice thanks..
  7. delaney
    delaney Formula Junior
    Nov 8, 2003
    721
    Montgomery TX
    PETER DELANEY
    Maybe some help on the flasher relay.
    Had a 308 and the unit went bad. Went to Ferrari ..$155 but not in stock. They sent me to Porsche ..$55 but not in stock ... they sent me to VW .... $19.95 ..bingo! All Bosch units ....identical unit but no little yellow horsey.
    Take the unit to VW and see if they can cross reference for you.
    Regards,
    Pete
  8. YOSHI
    YOSHI Rookie
    Aug 9, 2006
    48
    Northern New Jersey
    Where is turn signal relay on 355? Around foot area of passenger side, right?
    I can't find it.
    Thank you.
  9. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    My 308qv shows an Italmec 0027700 - for the flasher relay.
    Do you have the Bosch Cross Ref #?
    (mine has the ep-36 in it now, I'd like to get the Bosch or Italmec.)
    Steve
