Ferrari SD2 Cable Replacement or Repair? | FerrariChat
Discussion in 'Technical Q&A' started by [email protected], Jan 19, 2010.
  1. steveb@motorcars-intl.com
    Jul 14, 2006
    22
    I am looking for a replacement RS232 cable (goes between the Laptop and the SD2 box) with the round connector end.
    If you have upgraded your diag tools and have a spare let me know I woudl be interested in purchasing it. If you have ever had one repaired and have a contact for repair let me know.
    Stephen Burks
    Motorcars International
    [email protected]
    ofc: 417-831-9999
  2. AceMaster
    Feb 6, 2009
    34,766
    Ontario, Canada
    The RS233 cables can be found at any computer sales store - is the end on the SD2 different than the standard RS232?
  3. CarloR
    CarloR Formula Junior
    Sponsor
    Dec 13, 2006
    435
    9219 Mira Este Court, San Diego CA 92126
    Carlo Rubio
    #3 CarloR, Jan 20, 2010
  4. CarloR
    Sponsor
    Dec 13, 2006
    435
    Carlo Rubio
    Anyone recognize that circular barrel fitting end? if so... where do I get it and I am not shy to splice some wires and reconnect them. thanks..
  5. Rifledriver
    36,859
    It is an easy matter to open the box and install a commonly available plug. I saw a number of Challenge team SD2's that saw rough service and broken cords get that modification.
    Don't be shocked when you see how little is in that expensive box.
  6. Skidkid
    Skidkid F1 Veteran
    9,500
    Campbell, CA
    John Zornes
    It looks like a bayonet connector. They are used in military & commercial equipment because they don't just pull off and they are quick connect.
  7. CarloR
    Sponsor
    Dec 13, 2006
    435
    Carlo Rubio
    Thanks Brian! I will check into this today. good call!
  8. Rifledriver
    36,859
    In this application that is part of the problem. Due to the nature of its use the cords wind up being strung across the floor and they get tripped over. They really shoud be simple pull out connections.
  9. Diablo
    Diablo Formula Junior
    Get your dealer to order one, if you have a guy on the inside.
    That cable is avail separately.......I heard...
  10. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Most Sd2's i've used in dealerships over the years have had that crummy plug replaced. As Rifledriver said, it's not a good choice of plug for that application.
  11. CarloR
    Sponsor
    Dec 13, 2006
    435
    Carlo Rubio
    What did they replace it with if you don't me asking do you happen to remember? or know the style of connector? I may crack open this thing and do it myself. thanks..
  12. kerns577
    kerns577 Karting
    Oct 21, 2007
    89
    Sarasota Florida
    Sean Kerns
    I may have an answer before the end of the day. Cables to go can make a replacement cable for 50 dollars are less, if they have a diagram of the conversion from the 9 pin R232 to the 6 Pin barrel connector.
    If anyone has this information, please forward and I will post the quoted price and availability
