Ferrari Wheels Made of Butter? | Page 8 | FerrariChat
Discussion in 'FF/Lusso' started by msgm1, Feb 27, 2021.
  1. ttforcefed
    ttforcefed F1 World Champ
    19,269
    ok before i got blow another 1600 on tires i put 150 miles on, is this the absolute largest size i can go with?
    anyone want 4 brand new PS4s with 150 miles?
  2. ttforcefed
    19,269
    And cant i just do the fronts?
  3. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Running the 245/40R20 fronts with 295/35R20's is not an option unfortunately. That change in front to rear difference is beyond what the ABS/RSC can deal with. You need the added diameter of the 315/35R20 rears.
    Caeruleus11 likes this.
  4. ttforcefed
    19,269
    Ok thanks. Gonna try them on my spare wheels. May just go with the veds all seasons that way i can keep them on all year
  5. ttforcefed
    19,269
    has anyone run the quatracs?
  6. ttforcefed
    19,269
    looks like weak sidewall reviews
  7. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    otakki and Caeruleus11 like this.
  8. ttforcefed
    19,269
  9. ttforcefed
    19,269
    Are the lusso wheels im running the same exact dimensions of the split spoke ff wheels?
  10. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    The rear offset is different. The Lusso rear wheels has 10 mm less offset. The rim width is the same.
  11. ttforcefed
    19,269
    I owe you a dinner whenever you are in New York… Continentals ordered and going on the lusso rims tomorrow or Tuesday. If this works well for the summer I will get the equivalent size vreds for the winter
    vraa, Bundy and Caeruleus11 like this.
  12. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Thank you so much for that and I might just take you up on that. But really, you don't owe me anything. This is what this forum is all about:)
    Remember that if you go with the winter boots like Jerry did, the rears should be 275/40R20 rather than 315/35R20.
    I talked to my buddy from Michelin earlier today by the way, and just ran the size vs. pressure by him. Start by trying 30 psi in the rear and 32 psi in the front. They may like even less, but start there. I know the rear pressure seems low, but that's a big addition in volume compared to the original 295/35R20.
    Put up some pics when you get them on, so that others can see how those tyres look on the FF:)
    otakki and Bundy like this.
  13. ttforcefed
    19,269
    I think if i run 30 the tpms will come on.
    Oh boy i will definitely forget about the rear sizes when the winter comes. Ill do what i always do and ask jerry first!
    Caeruleus11 and Bundy like this.
  14. Bundy
    Bundy Formula 3
    May 18, 2011
    2,474
    Arizona & Kentucky
    Anir
    Ricky, I think you can reset the TPMS and it should be ok. This worked for me with lower pressures on the 812. Good luck!
    LARRYH and Caeruleus11 like this.
  15. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    30 is what the Pirelli winter tyres should be, so that is within the reach of the system.. Just set the pressure with a gauge and reset the tpms.
  16. Caeruleus11
    Caeruleus11 F1 World Champ
    11,704
    Just reset the system- its in the menus- the car needs to be on and stationary, fiddle around and you’ll find something that says reset TPMS. You may need to drive for as long as 40 minutes before they come back. Hopefully its sooner. I had it take a while once.
    Its interesting, with my unscientific fiddling around I have settled on 30 front and 32 rear (for the 245/40 // 275/40 combo) - could it be I wrote it down backwards? Its a lot more volume of air on both no?
  17. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    No, that sounds about right.
    When I talked to my contact at Michelin yesterday, the 32/30 numbers were very much a starting point based off of the problems with blowing out tyres. He was actually suggesting 30/29 but we decided that it might be better to air on the side of caution to start with. It's easier to start safe and take it from there. It also depends on the temps. If the hot pressure don't spike and go high, then it should be fine. Looking for 33-34 psi hot on the front, so 32 is a good place to start. If it goes above, then it's time to drop it to where it should be.
  18. ttforcefed
    19,269
    The Contis have been put on and the car is struggling to find the right gears. It drives terribly and shutters at all speeds. Thoughts?
  19. ttforcefed
    19,269
    Conti tires on lusso wheels on ff
  20. vraa
    vraa F1 Rookie
    4,599
    Texas
    Mr. A
    Shudders? Balanced properly?
    Do yall have discount tire up there?
  21. ttforcefed
    19,269
    Yes balance properly… Don’t think we have discount tire but not sure
  22. ttforcefed
    19,269
    it seems the car needed a cntrl- alt - delete. actually feels fine now. will test again later.
  23. ttforcefed
    19,269
  24. ttforcefed
    19,269
  25. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    My guess is that the ABS needed a re-cal. After driving a bit, the system will read the ABS ring on the tyre.
    The 4RM system in the FF is a bit less sophisticated than that of the Lusso, so it might be a bit of a slow learner.
    Sometimes you can reset by disconnecting the battery for more than 10 minutes. This will reset what the gearbox have learned from your driving style as well as the ABS etc.
    But seeing that the car seems to already having figured it out, I see no need.
