Ferrari Wheels Made of Butter? | Page 9 | FerrariChat
Discussion in 'FF/Lusso' started by msgm1, Feb 27, 2021.
  1. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Did you confirm those pressures with a gauge? Seeing the temps, going from 32 to 38 seems a bit off.
    Try driving till they are hot and then confirm the pressures with the same gauge you used to set cold pressure with. Again, the TPMS is not very precise.
    I set my 488 pressures today. I verified with two gauges that read the same. However the TPMS was off by more than 0.2 bar. In the front and off by 0.1 in the rear. A good gauge is a must.
  2. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
  3. ttforcefed
    ttforcefed F1 World Champ
    18,874
    VColin, crinoid, otakki and 3 others like this.
  4. ttforcefed
    18,874
    Will try it with the meter on my air pump
  5. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
  6. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
  7. ttforcefed
    18,874
  8. ttforcefed
    18,874
    Caeruleus11 likes this.
  9. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
  10. Caeruleus11
    Caeruleus11 F1 World Champ
    10,894
    That pressure move is similar to what I see also.
  11. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    I have DWS 06 in oem size for the front for the past year, but would love to go with the new sizes. Hopefully the proper psi would have been fully ironed out by that time;). Any rubbing with the larger DWS sizes as suggested?
    The original DWS was well known to have soft sidewall. Part of the "06" update was added ribs to the sidewall; that improved the condition but still was not adequate. Thus many users recommended running 2-4 psi above oem psi. For this last "plus" update earlier this year, I did not see any mentioning of increasing side wall stiffness.
  12. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    They are BIG balloons with reinforced sidewalls (XL). Doubt a weak sidewall will be an issue. The OE shoes are pretty soft too.
    No rubbing.
    otakki likes this.
  13. vraa
    vraa F1 Rookie
    3,575
    Texas
    Mr. A
  14. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    If this is not too common for you, perhaps consider trying replacing just the fronts with 255/35Re0. They will run with your stock rears.
  15. ttforcefed
    18,874
    How long have you had the car and what number rim is this?
  16. vraa
    vraa F1 Rookie
    3,575
    Texas
    Mr. A
    I've had the car since Nov 2020
    It came with two sets of wheels, one had the oem summer tires (pictured above), the other set had winter tires which I replaced with r compounds lol
    I haven't had to replace any wheels yet - but then I'm super paranoid how I drive
    I might end up just doing a set of two, I don't want to replace all the tires, but the age of the rears is concerning - 2016 means 5yrs old
  17. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    The Michelins age quite well, so I'd say just wear them down. Can't take that long anyhow:D
    Then when they are done, look into upsizing.
  18. vraa
    vraa F1 Rookie
    3,575
    Texas
    Mr. A
    So upsize to 255/35/20 now on the fronts, and then to what on the rears when I'm ready to replace the rears?
  19. ttforcefed
    18,874
    Bundy likes this.
  20. vraa
    vraa F1 Rookie
    3,575
    Texas
    Mr. A
    Interesting, I'm going to do 255/35/20 Michelin PS4S on the fronts and I'll try to do 315/35/20 Michelin PS4S on the rears when it's time to swap out the rears
  21. ttforcefed
    18,874
    The 255/35 didnt help me as I documented in this thread.
  22. vraa
    vraa F1 Rookie
    3,575
    Texas
    Mr. A
    I'm hoping my more paranoid driving will fare better, I didn't have any issues earlier - but I drive incredibly paranoid, I'm always looking for potholes or any deviations in the road
    ttforcefed likes this.
  23. ttforcefed
    18,874
    Fwiw the contis are very comfortable!
    Bundy and Caeruleus11 like this.
  24. vraa
    vraa F1 Rookie
    3,575
    Texas
    Mr. A
    Plus they last a lot longer too, 300 vs 560 UTQC I think
  25. aureux
    aureux Rookie
    Mar 14, 2021
    40
    Ontario, Canada
    John M
    Going to a 19 front was the best thing I've done to the car. I recommend to anyone having issues.
