FF Air Conditioning blows warm | FerrariChat
Discussion in 'FF/Lusso' started by IDriveM5, May 24, 2021.
  1. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    Hi Folks,
    Did a search, couldn’t find an answer. My 2012 FF with 30k miles is going into the summer with a weak air conditioning system. Had it out for 5 hours yesterday (outdoor air temp = 90F) and it basically blows warm air. Settings: 72 degrees, auto, snowflake on, and nothing cold. Has anyone had a similar experience? Wondering what some of the causes have been so I might be prepared when I take her in. Looking for solutions, that have worked, complexity, and approx costs please. Thank you.
  2. Caeruleus11
    Caeruleus11 F1 World Champ
    11,634
    I don’t know if there is something Ferrari specific but it could be simply low refrigerant.
    vraa likes this.
  3. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    That’s what I’m hoping for but I was wondering if other owners have had different experiences.
    Caeruleus11 likes this.
  4. kimwizzzuuu
    kimwizzzuuu Karting
    Aug 26, 2018
    240
    new york
    Kim
    I had this issue once in my gtc4lusso, for some reason from the infotainment screen doesn’t show outside temperature. Then AC start blowing hot warm to hot air. Image Unavailable, Please Login
  5. Wazzer
    Wazzer Karting
    Jun 23, 2020
    67
    Detroit
    Waz
    My 2012 FF just had the same problem! Technician discovered that it had little to no refrigerant in it. He pressurized the system and monitored it for 12 hours and could not find any leaks. He used UV to try and find a leak and saw lots of fluorescing around the valve caps but no where else. Solution so far was to refill the refrigerant and wait and see how long it lasts. So far so good. Total cost of labor for the diagnostic and refrigerant was just under $300.
    vraa likes this.
  6. IDriveM5
    IDriveM5 F1 Rookie
    Jul 2, 2012
    2,675
    Central Ohio
    Raj
    Thanks so much, I’m thinking this is going to be the first line of diagnosis and recharge. My mechanic thinks the same way as this solution but hasn’t seen the car yet. Really appreciate the advice.
    Wazzer likes this.
