FF Coolant leak | Page 2 | FerrariChat
FF Coolant leak
Discussion in 'FF/Lusso' started by cromwrima, Mar 9, 2025.
  1. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,808
    Weston, MA
    Paul
    Keep us informed!
    BTW, I noticed -
    South Dakota / Maryland
    Do you commute daily? :D
  2. NbyNW
    NbyNW F1 Rookie
    Nah, not daily but every few months. Tweaking our schedule, plus it’s based on seasons. It’s a nice cross country trip, good to see the country. We do it in an S Class - really nice for covering lots of miles.
    Nospinzone likes this.
  3. NbyNW
    NbyNW F1 Rookie
    Both hoses are leaking and need to be replaced. It's a mess under there and so clean on the shiny side.
    Manual says 16.9 L of coolant. Guess I'm going to make a mess - this is why I don't like working on coolant systems. Go slow with a 5 gal bucket.
    Is Valvoline Zerex G-05 the right coolant? I've also seen BMW coolant is ok. So many threads on the right coolant.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    ANOpax likes this.
  4. papou
    papou Formula 3
    1,748
    plantation Fla
    daniel ross
    Can you use after market hose, and avoid Ferrari tax.
  5. NbyNW
    NbyNW F1 Rookie
    Don’t think so, the left hose is evidently different sizes on each end. It’s $306, from valve to radiator, and it’s backordered and no NA dealer has one. A dealer is trying to get it from the UK. Might take a week or so. The right side return hose looks more standard and it’s only $4x. I should have that hose and all the clamps tomorrow.
    For coolant I used Mercedes brand in my 360C when I had it. Anyone know it that’s ok to use?
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,088
    Central NJ
    Dominick
    The correct coolant is g40 zerex
    NbyNW likes this.
  7. NbyNW
    NbyNW F1 Rookie
    It’s done. The hose via the UK was delivered yesterday (part #260080). Pretty easy job for both hoses. Took a few hours, slowest part was carefully draining the coolant so not to make a huge mess. Slightly over 3 gallons came out. I was expecting more. The dynamic process for filling described in the shop manual takes time too as it gets hot.
    The drivers side hose was a mess along with the metal fitting. I cleaned it up pretty well. The passenger side hose fittings were fine, just wiped them off. Even clean it was still leaking. Both hoses were swollen and worn.
    While in the garage I also changed the oil in our S Class. Done with everything by 1pm.
    Afterwards my wife and I went for a nice drive in the countryside. No leaks and all good.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    kenwidmerpool likes this.
  8. squishy
    squishy Karting
    Dec 11, 2022
    87
    NJ
    Steve L
    Glad to hear you were able to take care of this yourself. I had a similar issue for a Lusso, plus the water pump was leaking and needed to be replaced. Covered under Power 15.
    NbyNW likes this.
  9. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,362
    The Netherlands
    That’s interesting as my water pump leak was not covered under the old New Power warranty.
  10. squishy
    squishy Karting
    Dec 11, 2022
    87
    NJ
    Steve L
    Hey AN0pax!
    I’m sorry that ski season is over. I’m happy with the Stockli Laser SCs that I got this spring. I was able to go to Park City a couple of weeks ago and improved my CARV score by 10 points.
    Yes, the water pump was covered. The leaking radiator hose was not, but that was relatively inexpensive.
    ANOpax likes this.
  11. NbyNW
    NbyNW F1 Rookie
    Less than $500 in parts was good too. And most of that was the one hose.
    flash32 likes this.
