FF Coolant Smell/ Oil Leak | FerrariChat
Discussion in 'FF/Lusso' started by renntech36, Oct 19, 2017.
  1. renntech36
    renntech36 Rookie
    Jan 10, 2006
    3
    Hey Guys,
    Just bought a 3800 mile FF and upon my first drive, I noticed with the windows down that the car resonates a Coolant/AntiFreeze Smell. Put it on a lift, but didn't see coolant anywhere. I did however notice a small drop of oil on the back of the block, passenger side, close to the oil pump. Also small seepage coming from the Oil Filter itself.
    Any ideas on where to go from here? (besides the dealer) which I will be doing shortly. More interested if anyone else has had these issues.
  2. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    oil leak from the pump or filter might be simple fixes such as wrong torque used, or bad seals. Regarding the coolant, you should try and monitor the coolant level to make sure you are not losing any. It might just be that they spilled some during the last maintenance and it hasnt all dried up yet.
    of2worlds likes this.
  3. Tony102385
    Tony102385 Rookie
    Oct 10, 2012
    46
    oil/water pump are one. mine was leaking from weep hole and was replaced under warranty.
    PhantomCypher likes this.
