FF ownership after 6+ years | Page 6 | FerrariChat
Discussion in 'FF/Lusso' started by ttforcefed, Sep 1, 2018.
  1. papou
    papou Formula 3
    1,748
    plantation Fla
    daniel ross
    The code read fuel starvation or tech speak that means the same
  2. Shmichael
    Shmichael Karting
    Sep 23, 2022
    59
    Orange CT
    Sean-Michael
    I've seen that before . . . no bueno! But that was mine. These cars have some gremlins that appear and disappear. Sometimes it is nothing. A code should inspire curiosity and observation instead of a home equity loan application.
    VColin likes this.
  3. papou
    papou Formula 3
    1,748
    plantation Fla
    daniel ross
    Now that’s funny
    Shmichael likes this.
  4. ttforcefed
    ttforcefed F1 World Champ
    19,278
    updated:
    Date Miles Work Price
    2/27/2012 1,720 oil 0.00
    7/19/2012 3,697 PPF 4,300.00
    7/25/2012 3,701 oil, campaign #367 0.00
    9/24/2012 4,446 evap, driver mirror not flush, campaign #371 update PTU, campaign #379, software update, fix rim 710.00
    12/13/2012 4,458 oil, annual, campaign #381, software updates, detail 329.00
    4/17/2013 9,360 2 new wheels, detail 1,945.00
    7/16/2013 10,358 BT, battery dead 372.00
    11/12/2013 12,023 2 year service, oil, brake flush, pollen filter, air filters 230.00
    11/25/2013 12,024 Replace wheels 2,451.00
    4/9/2014 13,644 put summer wheels on and look for metal rattle 428.00
    9/24/2014 15,653 replace front cavallino, oil, pollen, loose bolt from pillar, electrical system failure error reset 183.00
    10/3/2014 15,775 Novitec exhaust, sport cats, ecu, x pipe 24,195.69
    6/16/2015 19,658 Driver seat ventilation comes on, repair front wheel. 253.00
    10/20/2015 20,285 annual, oil, brake flush, AC control belt 0.00
    6/9/2016 Full Stereo 15,478.00
    8/18/2016 24,301 repair wheels 2,087.00
    9/9/2016 24,420 alignment off, rattle coming from both rear axle nuts, annual service, PTU gear oil 937.00
    12/28/2016 24,510 rattling from rear: replaced both rear rotors, campaign #413 897.00
    4/26/2017 24,579 new wheels GT4 lusso 6,735.00
    8/9/2017 25,163 CEL, annual maintnence, air filter 213.00
    9/29/2017 25,528 replace secondary air valve, cel, vent alert still 1,321.00
    11/24/2017 25,617 clean secondary air ports to rid CEL 213.00
    2/13/2018 26,100 replace battery, replace spark plugs 1,825.00
    5/21/2018 26,190 replace crushed vac hoses under intake, replace secondary air hoses 697.00
    10/17/2018 28,466 2 yr maint, oil, brake flush, airbag campaign 37.00
    10/3/2019 31,784 oil, brake, dct, ptu, rear diff 1,948.00
    10/2/2020 33,014 oil, brake flush, compression test, power warranty, battery 9,543.00
    2/8/2021 35,450 seat vent error still, broken clips from back squeeking, left rear shock, gearbox groaning, new gearbox 2,225.00
    4/22/2021 new wheels GTCR lussoe 3,153.00
    8/9/2021 37,052 4x4 manettino error, leaking ptu, replaced ptu, passenger heat indicator 446.00
    5/1/2023 39,470 oil change and rear brake pads 2,705.00
    11/22/2023 40,435 brake fluid cap replacement recall 0.00
    12/13/2024 40,729 drive belts, ignition coils, dct, ptu, coolant, power steering, brake fluid, valve cover gaskets etc 10,949.00
    Total 96,805.69
  5. Jaguar36
    Jaguar36 Formula 3
    1,153
    Cherry Hill, NJ
    Seems like you go through an awful lot of wheels, are the roads around you particularly bad or something?
  6. ttforcefed
    19,278
    40 miles north of nyc.
    i have been through at least 25 wheels so far. went to beefier tires a few years ago.
    Wazzer likes this.
  7. Qksilver
    Qksilver F1 Rookie
    4,586
    PC, UT
    Joe
    With $40K being elective, if we back that out, your spend of less than $5K/year to essentially daily drive the car is pretty darned good Ricky!
    kenwidmerpool likes this.
  8. ttforcefed
    19,278
    if you exclude ptu, dct, $25 to $30k of tires
  9. Qksilver
    Qksilver F1 Rookie
    4,586
    PC, UT
    Joe
    Yeah your running costs are excellent.
  10. whoaitswee
    whoaitswee Karting
    Mar 30, 2024
    50
    Tennessee
    Huy Tran
    following! thanks for posting
