FF Routine Maintenance | FerrariChat
Discussion in 'FF/Lusso' started by NbyNW, Nov 10, 2024.
  1. NbyNW
    NbyNW F1 Rookie
    Oil and filter, brake fluid flush, air filters. Battery soon.
    Hardest part was getting the old oil filter off. The tech at the dealer where it was CPO last year did a number on it. It took about all the grunt I could muster to get it off. Damn. I tried to torque the new one to 30nm, but it was so tight with the torque wrench I probably over did it a little too. Hand tight next time in a year.
    Used Motul 8100 X-power, 10W-60 and Motul RBF 600.
    Straight forward job. I didn’t do the two front oil lines. Figured with 13L of oil, new filter, and low miles it’ll be fine.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    whoaitswee, dustywusty, donv and 3 others like this.
  2. NbyNW
    NbyNW F1 Rookie
    New battery. Interstate from Costco. MTX-49/H8, AGM. After reading most of the threads here I got myself pepped for lots of aggravation. Wasn’t that bad after all. Some points of BS that are engineered in but easy to work around them. Start to finish was 2.5 hours with a slow start.
    Wasted way too much time trying to secure the hold down bolts so they wouldn’t drop to who knows where. Plus super careful not to drop their nylock nuts and washers. I ended up using a couple alligator things from Battery Tender connectors. Worked well to hold them up and out of the way.
    A few pictures if it helps anyone.
    Starting point.
    Loosen the negative bolt, blue, to swing the cable out of the way. Remove the negative quick connect point, green. Then remove the hold down plate.
    As others have said, what the hell is this thing in red for?! Just gets in the way but wasn’t as bad as I was expecting. The blue item was a pain too. Interfered big time when putting the new battery in.
    Generally, adequate space. My zip tie trick to hold up the hold down bolt didn’t work. The left/passenger side hold down bolt really grabbed the heat shield so had to work it in just right. It’s the heat shield side that folds over and snaps closed.
    New and old.
    Old battery.
    Last time supposedly changed by an F dealer during CPO. Didn’t think they used Interstate. Maybe they fudged the paperwork.
    Old.
    Process…
    The clamp/bracket that would not let the new battery pass. Plus its bolt was very loose. Found another loose bolt too.
    Elferink likes this.
  3. NbyNW
    NbyNW F1 Rookie
    More…
    I made a bracket to hold it back and held in place with gaffer tape. Worked great. Battery slid by. In blue is my trick to hold those bolts out of the way.
    The side of the heat shield that grabbed on the bracket thing. I wasn’t the first to deal with it.
    It’s in.
    Reconnected.
    Back together and everything reset and working.
    Elferink, Nospinzone and ANOpax like this.
  4. NbyNW
    NbyNW F1 Rookie
    Looking back at my pictures maybe I bent that bracket piece. Either way, it’s in.
  5. NbyNW
    NbyNW F1 Rookie
  6. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,352
    The Netherlands
    #6 ANOpax, Nov 30, 2024
    Just did my battery today. It took 30 minutes from start to finish (this isn’t my first battery change :cool:)
    A couple of points to speed things up;
    1 it isn’t necessary to remove the oil filler cap.
    2 it isn’t necessary to remove the negative quick release cable from the tie down bar.
    New (the camera didn’t catch the full CCA but it was 1184)
    Old (the CCA wasn’t as weak as some old batteries that I’ve pulled but cranking is consistently slow, leading to electrical dropouts. We are going skiing in a week and with the sub-zero temps, it’s asking for trouble using a 3.5 year old battery, especially given that I normally change them every two years)
    Elferink, Nospinzone and NbyNW like this.
  7. NbyNW
    NbyNW F1 Rookie
    Next time will be much quicker. Agree on your 1 and 2. I followed the lead from other posts. Definitely an easy DIY.
    ANOpax likes this.
