FF Steering Wheel Lights/Mannetino Flash on Startup - Lithium Battery | FerrariChat
Discussion in 'FF/Lusso' started by veelangs, Dec 8, 2022.
  1. veelangs
    veelangs Formula Junior
    Sep 27, 2021
    310
    Manhattan
    Vee
    Been going on for some time, I had an Antigravity Lithium battery installed in my FF to combat NYC Ferrari Ownership. The battery solved my needs for a reliable start but it does two things on startup that drive me mad. It throws a bunch of errors while the electrics "warm up" (which boggles my mind that electrical currents need to warm, but alas) and more annoyingly the lights/driving zones on the steering wheel flick on and off and the computer doesn't recognize the mannetino state nor do any of the buttons on the wheel save for the ignition work (especially annoying because the turn signals and wipers don't work).
    This started off being 30 second thing and I chalked it up to the cranking power of the battery vs an AGM battery. But it has been getting a bit longer lately and just the other day the car was at the dealer for annual and the service manager told me it happens nonstop. I'm gonna have my bud and I take out the lithium battery and pop in the AGM again and see if that fixes it, but it doesn't really make sense that that should be the issue.
    Anyone with a Li-Ion battery or otherwise have this issue?
  2. veelangs
    Sep 27, 2021
    310
    Manhattan
    Vee
  3. Bonovox09
    Bonovox09 Rookie
    Sep 4, 2022
    27
    Concord, MA
    Bruce Thompson
    Same thing happens to me after installing new battery. But that also coincided with onset of cold weather. The electrical warning and flashing stops if I let the car idle for 15 mins or driving for a few miles. Once I drive for awhile this doesn’t happen again during day — only next day an am when cold. Leaving car on battery tender doesn’t help.
    The tech says the battery lead wasn’t in good shape and we’ll replace that and see if it helps.
    there are several past threads on this issue.
    someone posited a theory that it might be related to a fuel line sensor which might trigger when it’s cold out — maybe due to condensation?
  4. veelangs
    Sep 27, 2021
    310
    Manhattan
    Vee
    I'm of the same opinion as you that it's just when the engine is cold because you're describing the same thing as mine. I can live with it because it's really not an issue but I was more concerned that it had gotten longer lately. No one wants to wait 30 minutes to drive their car
  5. Bonovox09
    Bonovox09 Rookie
    Sep 4, 2022
    27
    Concord, MA
    Bruce Thompson
    Let me know what happens and Ill do same.
    veelangs likes this.
  6. SVCalifornia
    SVCalifornia F1 Rookie
    2,552
    Silicon Valley
    Keith
    My AG Lithium has been flawless. Albeit in warmer weather.
    I doubt this is the battery. But perhaps a full power reset will help. Remove ground cable then reinstall.
    SV
  7. veelangs
    Sep 27, 2021
    310
    Manhattan
    Vee
    Need to do a power reset, but timed it and it took~6 minutes to stop flashing.
    Annoying? Sure but not the end of the world
  8. veelangs
    Sep 27, 2021
    310
    Manhattan
    Vee
    Just updating this for anyone who might have the issue, did a power reset of the battery and everything and it fixed the issue...for a bit and it's been slowly coming back. Really no clue why, but hey it's only 30-40 seconds right now. If I just gotta do this every 6 months of so I can live with a battery terminal pull.
    350MH83 likes this.
  9. ttforcefed
    ttforcefed F1 World Champ
    19,223
    shld probably try a regular battery and see if the issue goes away
  10. dustywusty
    dustywusty Formula Junior
    302
    Florida
    That's odd -- the Antigravity I had in the FF was flawless. Did you get the 80ah?
  11. veelangs
    Sep 27, 2021
    310
    Manhattan
    Vee
    yep I have the 80amp
    Seems to work just fine except this flashing mannetino thing
  12. dustywusty
    302
    Florida
    Dang, man. I wonder if you’ve got a bad one. Could be worth a call to antigravity.
  13. veelangs
    Sep 27, 2021
    310
    Manhattan
    Vee
    maybe, who knows. The car went to Braden the other day for service and they told me the Can Network wasn't responding correctly (don't know what that is personally) and that's causing the flashing steering wheel.
    We'll see what they report back to me
    dustywusty likes this.
  14. sid12345678910
    sid12345678910 Karting
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    #14 sid12345678910, Feb 14, 2023
    Are all the steering wheel lights flashing on and off? and after a while it stops? I just fixed this issue myself it had nothing to do with the battery (I replaced mine thinking it was). the link you sent is dead.
    Mine turned out the be the steering wheel control module, NVO. I fixed it by doing PCB repair. Cost me 5 quid
  15. veelangs
    Sep 27, 2021
    310
    Manhattan
    Vee
    Interesting! The tech that has it right now says my radio is causing it. But I'll point this out to them as well
  16. SVCalifornia
    2,552
    Silicon Valley
    Keith
  17. sid12345678910
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    https://youtube.com/shorts/in-GBjdNp5A?feature=share
    Here a video showing what happen to mine. In the video I just cleaned it to see if it would work. That didn't. I then used a thermal camera to have a look at it to see if there were any shorts on the PCB.
    See video
    So established that about 6 compentents could be shorted. The voltage regulator and some darlington transistors pairs.
    I ordered those parts for bascialy nothing swapped out the smds on my hot air reflow machine. I then probed around the pcb to see if the short was gone and still found a short and after about 2 hours of probing I found a shorted capacitor aswell. Luckily I had a spare smd cap with a similer value so I swaped that aswell.
    Here are the bad components
    And the new ones I ordered after identifying them
    This whole ordeal took about a month to sort out. Ferrari won't sell you just the pcb. You have to buy a whole new button panel. Scudria car parts sells them for about 1750 pounds. My dealer wanted 2500 pounds to fix the issue.
    I fixed it for about 5 pounds. Not including the tools obviously....
    I skipped over some finer details like part no because in each case a different component will fail and it's only with proper smd repair tools and skills you can garentee a fix. But essentially you could litrally buy every single tool I used to fix this problem and still come out quite ahead if you had got the dealer to fix it.
  18. sid12345678910
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    I also should mention they way I figured out that it was the NVO was with my launch x431 Diagun V.
    You can ignore the transmission error
    This was caused by the infamous speed sensor which I just had done at the dealership.
  19. SVCalifornia
    2,552
    Silicon Valley
    Keith
    Looked like each of the transistors were the LED drivers?? A bad transistor should result in a bad LED location. Wouldn’t expect that based on the symptoms.
    Vreg if it were firing up then down (overcurrent sense?) might cause the symptoms tho. Ceramic caps don’t often go bad unless they over voltage. Any idea if these are just filter caps or some kind of compensation caps?
    SV
  20. sid12345678910
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    #21 sid12345678910, Feb 15, 2023
    Im not sure what the transistors were doing tbh, all I know is that they are a prebiased n-p-n transistor with a prebiased p-n-p one. I think that is just a Darlington pair but I could be wrong. It could be possible they were completely fine. they measured correctly in terms of resistance to the gate, but I replace them regardless.
    What I think was actually wrong was probably with the voltage regulator and the shorted cap. The cap wasn't a complete short it was a around 150Ohms to ground. It was on the 5V line for the led power. I'm pretty sure it was just a filtering cap. It could have been that solely causing the issue.
    The voltage regulator has a reset pin, I read in the documentation that if not enough filtering capacitance was on the output line it can cause instability. And will cause it to reset constantly. I think this was exactly what was happening. Again no idea if i was right since I just replaced everything all at once.
    Transistors replaced:
    PDTB123ET
    MMUN2211L
    Voltage Regulator replaced:
    L4949ED
    I don't remember the capacitance of the cap, sorry. its obviously rated for above 5V. I think it was 10nf 0805. Its just a filtering cap so just stay below 10uf.
    Again if anyone is reading this and has this issue replacing these components may not work. That's not how SMD repair works.
    SVCalifornia likes this.
  21. timemachine
    timemachine Karting
    Dec 8, 2009
    189
    Hartland Michigan
    John Meaney
    Hey Sid,
    Awesome job of troubleshooting and repairing! You said "it had nothing to do with the battery (I replaced mine thinking it was)"....Were you using an AG battery too and swapped to a AGM or SLA and still had the same problem? Could you just clarify this pls?
  22. sid12345678910
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    I used the exact same battery for replacement. It was a varta agm battery replaced with the same varta agm battery. Like I said before I checked the old battery with a battery tester and it tested healthy.
    Battery model:
    VARTA 595-901-085 Silver Dynamic AGM G14 (95Ah)
    kenwidmerpool likes this.
  23. timemachine
    timemachine Karting
    Dec 8, 2009
    189
    Hartland Michigan
    John Meaney
    Thanks for the clarification.
  24. Bonovox09
    Bonovox09 Rookie
    Sep 4, 2022
    27
    Concord, MA
    Bruce Thompson
    ______________________
    Folks -- just wanted to let you know the issue has been resolved. I had the electrical warning on cold mornings and then eventually began to get an engine warning light. The problem was a faulty Canister Purge Valve, which is electrically operated.
