FF Steering Wheel on Exit not working?? | FerrariChat
Discussion in 'FF/Lusso' started by MikeWHO, Jan 24, 2014.
  1. MikeWHO
    MikeWHO Rookie
    Dec 12, 2013
    5
    Chicago
    Help!
    My FF's steering wheel used to raise-up to the highest position upon turning off the ignition.
    Now it just stays at the driving position on exit.
    Is there a switch or button I bumped by mistake?
  2. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Mine just stays at the driving position, and it came that way 2 weeks ago. Maybe there is a setting for it?
  3. tazandjan
    39,170
    The owners manual is not too complete, from what I can see, unless there is another separate manual for what is available as options in the screeens.
  4. Sestri
    Sestri Rookie
    44
    SF Bay Area
    Reset your seat memory position by pushing one of the memory buttons on the seat until you hear a "beep" - see if that will reset your steering wheel easy entry
  5. London John
    London John Formula Junior
    Sep 7, 2010
    560
    London & Melbourne
    Also, jiggle the position switch around a bit, it worked on mine.
  6. RickLederman
    RickLederman F1 Rookie
    2,837
    Swanton Ohio
    Rick Lederman
    I never knew it was supposed to move up ... guess I need to figure that out too.
    Rick
  7. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    My curiosity was piqued by the OP, so I verified that my '14's wheel doesn't move up either. I then looked through the manual and ... nothing. I checked all the set-up functions in the left TFT display and ... nothing. So I am scratching my head. It is a feature I don't really need and the car does not seem to have it. But maybe I missed something.
  8. London John
    Sep 7, 2010
    560
    London & Melbourne
    Well, it's there. Switch off the engine on mine and the wheel goes to it's highest position.
    You may want to check that a) your wheel is in an "out" position, i.e. extended to some degree away from the dashboard, and b) that your normal driving position isn't with the wheel at its highest.
    Mine didn't retract unless condition a, above, was satisfied.
  9. MikeWHO
    MikeWHO Rookie
    Dec 12, 2013
    5
    Chicago
    My wheel for my driving position is all the way out.. and near all the way down.
    I really miss having the easy ingress/egress of this feature since the FF is my daily drive.
  10. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    And it once worked for you. Oddly I can't call up the feature in my '14. Maybe they dropped it in recent builds (?)
  11. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Aha. It works. But it moves silently after shut off and is easy to miss.
  12. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    You are correct ... so easy to miss I missed it too, mine works just fine.
    Rick
  13. FFMAC
    FFMAC Formula Junior
    Jul 20, 2012
    397
    Mac
    And mine!
  14. MikeWHO
    MikeWHO Rookie
    Dec 12, 2013
    5
    Chicago
    Called my local Ferrari Dealer tech...
    He said it sounds like my drivers seat memory module might be going bad.
    According to him, there are no extra switches or settings, it should just work on exit.
    Today, the steering wheel exit feature started working again on it's own... LOL !!!
    Go Figure.
  15. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Hmmm. Often if a fault is intermittent it is a short. The techs hate to chase shorts, much prefer to replace a module. Keep this in mind.
  16. Zack
    Zack Formula 3
    Dec 18, 2003
    2,002
    Nicosia, Cyprus/Cali
    Zacharias
    Maybe moisture was shorting it out. Now that it has evaporated, things are working as expected again. Just guessing here.
