FF Transmission appears to be leaking | Page 2 | FerrariChat
Discussion in 'FF/Lusso' started by turbosonoma, Nov 5, 2018.
  1. otakki
    otakki Formula 3
    1,634
    Exactly, that's more than just leaking. It'll be too risky to drive that for long.
  2. FerrFan101
    FerrFan101 Rookie
    Nov 28, 2018
    15
    Doug Alekson
    I follow the shop Royal Autowerks on Facebook (they are out of Overland Park, KS) and I know the owner just finished rebuilding and documenting his teardown and prove-out of the Getrag 7DCL750, which is the DCT used in almost all the Ferraris since the 458.
    Jason (the owner) appears to the the expert on this transmission now after rebuilding his own FF from a flood car, including the transmission. This apparently included the SAP boards, the CCP board, clutches, etc. Full R&R.
    I'd suggest reaching out to them with any inquiries. They have been known to consult others on the forum for exotic car repairs, etc...
    ZeptoLira and otakki like this.
  3. Les499
    Les499 Rookie
    Sep 6, 2021
    1
    Les Costales
    Does the seal push out? What is the permanent repair or this issue will return depending on wear?
  4. nguyennhatquang
    nguyennhatquang Karting
    Feb 13, 2016
    202
    Hanoi
    The seal is worn out due to heat and times..
    some car has issue with the transmission shaft worn out or scrore.. but very very rare
  5. vraa
    vraa F1 Rookie
    4,501
    Texas
    Mr. A
    So those of us in hotter climates should expect higher rates of failure?
  6. peterman1234
    peterman1234 Rookie
    Oct 16, 2021
    1
    Panagiotis Mantziaris
    Which part of the transmission is this, do you have any more pictures? Thank you in advance.
  7. nguyennhatquang
    Feb 13, 2016
    202
    Hanoi
  8. ryalex
    Aug 6, 2003
    25,763
    Las Vegas, NV
    Ryan Alexander
  9. Vegas CS
    Vegas CS Formula 3
    1,126
    Vegas
    James
    And because of Rylex’s experizzle, imma get that warrantizzle for my F-twizzle. :D
    ryalex and ANOpax like this.
  10. ryalex
    Aug 6, 2003
    25,763
    Las Vegas, NV
    Ryan Alexander
    I will say, it was a massive relief to sign that $0.00 invoice. Buying CPO with warranty has saved me the cost of a brand new Camry. Nearly an Avalon.
    Oh and it was the same seal that went:
  11. isellair
    isellair Rookie
    Oct 2, 2018
    16
    I paid near $14K to have this gearbox replaced in NY. The Ferrari dealer I purchased my car from in AZ was not helpful with warranty 6-8 months after I had purchased the car. Buy the warranty
    ryalex likes this.
  12. Vegas CS
    Vegas CS Formula 3
    1,126
    Vegas
    James
    I need to visit the dealer and see if this has already been replaced in mine.
    ryalex likes this.
  13. emanueloko
    emanueloko Rookie
    Mar 8, 2021
    15
    Emanuel Pereira
    My mechanic told me to buy this
    I have 458 2013 is leaking a lot
    I just need the seal but
    Ferrari seller how kit
    I move Miami to San Mateo Ca
    Anyone know about this leaking?
    Is same seal
    GETRAG KACO 900.9.0481.60?
    Enviado do meu iPhone usando FerrariChat
  14. papou
    papou Formula 3
    1,714
    plantation Fla
    daniel ross
    Check out this guy , he is creditable..
  15. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Yes you have the same gearbox 7DCL750, and size
  16. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    1. All ferraris use same gearbox DCT from manufactur "Getrac" Model: 7DCL750
    But ferrari dealer and publics don't tell this information to customers, they trying to Keep buyers blind and donkey. To prevent users from ordering parts separately for this box. And we went to the dealer and bought the whole box complete with installation for $49,999. As they say, nothing personal, just business.
    2. This same gearbox was installed on Mercedes amg GT-s, and there is common problem with leaking seal from this cardan shaft seal. But on ferraris it's not common problem, it can be happens if: gearbox was rebuilded, for some reason you put overlevel of oil in DCT. Due of rare using of car, seal is dried up!
    3. DCT Getrack 7DCL750 is include the rear reducer inside, but this two systems is isolated and contain different oils, and it's Transmits torque with a small shaft inside, it's connected through same sealing ring. This system is not reliable LIKE ZF/PDK gearbox on bmw or porsche.
    4. If you seeing oil leak on cover - you cannot drive this car, you will destroy your DCT. Get recovery to workshop.
  17. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    I found a recall of a factory defect in 2015 (attached PDF) from a Mercedes dealer, on all amg gt models before 2015, and this oil seal is the problem, GETRAG KACO 900.9.0481.60
    So I hope ferraris after 2015 is don't have this problem.
  18. emanueloko
    emanueloko Rookie
    Mar 8, 2021
    15
    Emanuel Pereira
    My mechanic on Flórida told me to change this seal
    I need found a mechanic on Bay Area
    Is cheaper part I go try buy just the seal
    Is hard to change just this?
  19. emanueloko
    emanueloko Rookie
    Mar 8, 2021
    15
    Emanuel Pereira
    My friend I need remove the DCT gear box completely to change this seal?
    My mechanic told me easy to change
    Anyone know?
    How change more easy?
  20. Emirateshills575
    Feb 1, 2023
    152
    UAE
    X
    Yes sure
  21. nguyennhatquang
    Feb 13, 2016
    202
    Hanoi
    I made that video so if anyone want to repair can take a look
    sid12345678910 likes this.
  22. sid12345678910
    sid12345678910 Karting
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    lovely thread
    have the same leak on my ff, any other O-rings/ seals you guys recommend replacing?
    I found the seal online here
    https://www.transmida.lt/en/seal-238
    you need 2 pc's
    I was thinking of ordering these aswell:
    https://www.transmida.lt/en/seal-378
    this is where the shifting forks seal, 2pc come in this set but there are 2 sets on the gearbox
    https://www.transmida.lt/en/sealing-cap-4
    this is the small cap here on the top left
    https://www.transmida.lt/en/sealing-cap-3
    these are the 2 big caps in the middle
    anything else worth replacing? I could be wrong with my information above so if someone can correct me I would apricate it greatly!
    kenwidmerpool likes this.
  23. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,333
    The Netherlands
    Thanks for the photos, Sid. They’re really helpful.
    Are you replacing the speed and temperature sensors while the gearbox is split? If not, you might consider doing so.
  24. sid12345678910
    Nov 24, 2020
    50
    Hong Kong
    Sid V
    Already replaced both at the dealer, it seems once they took the transmission around 2 months later it started to leak. 2 possible reasons could be that they damaged it when reassembly or because its old and brittle it got jiggled around and broke when they reassembled. Regardless they didnt cover it under warranty but instead gave me a heavily discounted rate on labor and parts(still almost 8k usd) to fix. They replace the whole plate as thats Ferrari protocol. The deal is good when you consider the parts and labor cost. the labor at my inde is actally more expensive then the dealer but the dealer have to replace the plate which cost 4500 USD just in parts.
    My view is to find a good inde shop (which I already have) that I can provide parts and just pay labor. From the links I posted you can see the cost is almost nothing for the seals compared to a whole new plate. I should come out at almost half the cost compared to the dealer.
    kenwidmerpool and ANOpax like this.
