FF water temp range while idle in traffic | FerrariChat
Discussion in 'FF/Lusso' started by jhott66, Sep 15, 2022.
  1. jhott66
    jhott66 Rookie
    Feb 21, 2008
    22
    Pittsburgh
    Hi all,
    Those with a FF: what is your engine water temperature range while idling/sitting in traffic when ambient temperatures are above 75 degrees F?
    Just trying to identify some weird behavior of my car with respect to engine water temperature. It seems to easily approach 245F when idling in traffic. Even as quickly as idling at a traffic light.
    Thanks.
  2. bumcubed
    bumcubed Karting
    Apr 15, 2022
    67
    On a hot day between 90-100 deg celsius, over 100 if I push the rev count and I’m passing through a hot stuffy tunnel
    350MH83 likes this.
  3. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    The highest I have seen was 98DegC.
    otakki likes this.
  4. 21ATS
    21ATS Formula Junior
    Dec 10, 2016
    988
    Kent, UK
    Alan
    Same as above high 80's to 90 degrees C when running.
    Pushing 100 C when sat in traffic. Those engines produce a lot of heat.
  5. jhott66
    jhott66 Rookie
    Feb 21, 2008
    22
    Pittsburgh
    Thank you for the replies. I regularly see temps rise up towards 240F (115C) when I am sitting/idling in traffic. Temp falls as expected when moving along.
    This is in the northeast USA where we regularly see 90F and high humidity in the summer.
    I realize these engines generate a lot of heat but my water temperatures seem to get too high.
    I’ll have to start with a coolant change and replace thermostat. Start there.
    Thank you folks!
  6. otakki
    otakki Formula 3
    1,634
    As above, around mid 90 degrees C when outside temp is around mid 90's.
  7. Elasto
    Elasto Karting
    Aug 27, 2014
    142
    Vienna, AUSTRIA
    Andreas
    Maybe the coolant level is low.
    My FF hit 105°C when operating in stop-and-go traffic, even when outside temps where moderate.
    After adding coolant the problem's gone.
    FerRrari likes this.
  8. camshaft
    camshaft Karting
    142
    MA
    Austin
    If the car is at a stop and the engine temps are high you should be able to hear the electric radiator fans running. They are what circulate air over the radiators when stopped.
  9. Rostami6
    Rostami6 Formula Junior
    545
    Austin TX
    Amir
    I’m curious about this too. I’ve noticed temperatures reaching as high as 240 a couple of times recently. And this is just after an annual service which included coolant flush.
    So is this normal?
  10. Elasto
    Elasto Karting
    Aug 27, 2014
    142
    Vienna, AUSTRIA
    Andreas
    I have been told that the cooling system is pressure tested during the annual service, which can lead to some coolant beeing lost.
