FF - Will PTU trigger when sensor when low and what Hydraulic fluid are you using? | FerrariChat
Discussion in 'FF/Lusso' started by carguy007, Jun 26, 2023.
  1. carguy007
    carguy007 Formula Junior
    Apr 24, 2013
    897
    What kind of fluid are you guys using in the PTU Hydraulic reservoir? I can't find Shell TT 1055 online and is what the manual advises.
    Will the car alert me when the PTU fluid is low. I have 51k miles and not find any record of the hydraulic fluid being changed(Ferrari states lifetime fluid). The issue is my main fluid tank is not translucent and I can't look to see the level. I was thinking about adding fluid until it shows slightly in the overflow, but if there is a sensor I will just wait for it to trigger I suppose.
  2. ttforcefed
    ttforcefed F1 World Champ
    19,256
    i dont believe so as i dont ever remember anyone citing this in their ptu issue discovery journey, but maybe im wrong?
  3. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,785
    Weston, MA
    Paul
    What year is your FF? My 2015 requires a PTU oil change every 12,500 miles.
  4. carguy007
    Apr 24, 2013
    897
    2012 - Which PTU fluid is required to be changed at 12.5k miles? There are two as mentioned. Also the workshop manual does not even mention a change of the gear oil until 62.5k miles. Very curious where you are hearing this, but also would agree this is a great practice.
    Nospinzone likes this.
  5. Nospinzone
    Jul 1, 2013
    7,785
    Weston, MA
    Paul
    Interestingly the manual uses the term "replace" for oil and filters, but uses the term "change" for the PTU oil. Is there a difference between replace and change, go figure. o_O
  6. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
