FF with EPB failure | FerrariChat
FF with EPB failure
Discussion in 'FF/Lusso' started by George J Cost, May 16, 2022.
  1. George J Cost
    George J Cost Rookie
    Oct 7, 2020
    15
    Jax Florida
    George J Cost
    So I put a new head unit in the 2015 FF, and I got an EPB failure and NOT PROGRAMMED code on the dash. I did some research and I put the correct Can Bus in from navteck and it has a new battery that I installed after reading that it could be an electrical issue. So I am now stumped, I saw some post about the brake relay going bad. But I can not find one, so if anyone has any insight please help. Also, the brakes work fine, they are not locked up at all and the car drives perfect.
    G
  2. ttforcefed
    ttforcefed F1 World Champ
    19,257
    replace your battery...prob have a bad cell
  3. George J Cost
    Oct 7, 2020
    15
    Jax Florida
    George J Cost
    Brand new battery. Like a week old. Tested it before install.
  4. ttforcefed
    19,257
    Unfortunately just because it’s new doesn’t mean it’s bulletproof… Still might have a bad cell… Who I try to charge to full and see what happens
  5. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,569
    Austin TX
    You might do a CCA test, if the cold cranking amps are not at or above spec, the battery must be replaced...it is rare, but I have had that happen before, fresh "off the shelf" and it is below spec, so now I have a CCA testing tool in my cabinet...
  6. veelangs
    veelangs Formula Junior
    Sep 27, 2021
    310
    Manhattan
    Vee
    Had this same exactly problem all the time when my battery was borked (coincidentally from a bad headunit install)
    Replaced with an antigravity battery and it never happened again. Mind you Li-ion batteries are incredible but the car does throw up a bunch of errors for the first 10-20 seconds because it doesn't send as much juice to start but whatever, never a flat battery again!
  7. George J Cost
    Oct 7, 2020
    15
    Jax Florida
    George J Cost
    So after resetting the EBP calibration we are good to go.
    Caeruleus11 likes this.
