FF xenon bulb change | Page 2 | FerrariChat
Discussion in 'FF/Lusso' started by mfr456, Dec 9, 2020.
  1. 21ATS
    21ATS Formula Junior
    Dec 10, 2016
    988
    Kent, UK
    Alan
    There's a tab on the side next to the bulb that lifts up. This locks them in place.
    Lift tab, remove bulb, fit new bulb, push down tab to lock new one in place.
    Kainedogg and Bundy like this.
  2. Scout123
    Scout123 Formula Junior
    Nov 1, 2017
    573
    Thanks. I’ll dive back in again tomorrow and see if I can locate that tab and give it a shot.
    21ATS likes this.
  3. Scout123
    Nov 1, 2017
    573
    Yes, flipping the switch down definitely made it a lot easier to remove the bulbs. The new ones are much brighter. The OEM ones that were replace were Phillips.
    can’t wait to drive on a really dark road.
    21ATS likes this.
  4. hkg1997
    hkg1997 Rookie
    Mar 18, 2018
    24
    SF Bay area
    @21ATS I am able to take the bulb out but now I couldn't get the new bulb to sit properly....I am using your method to access the bulb from the engine bay. However I couldn't see inside the housing especially the tabs around....I tried for 30mins and give up. Any tips pls?
  5. HTheLetter
    HTheLetter Rookie
    May 27, 2023
    32
    H Phillips
    Small hands. Light. Contort head some. Take your time.
    It took a few attempts when I replaced mine with Osram CBB but got it.
  6. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    I was thinking that maybe the battery is better accessed from the wheel well?? :D:D:D
  7. hkg1997
    hkg1997 Rookie
    Mar 18, 2018
    24
    SF Bay area
    Does it need to push real hard? I tried to push very hard but still wont go much in.
  8. HTheLetter
    HTheLetter Rookie
    May 27, 2023
    32
    H Phillips
    No I don’t recall needing to push hard.
  9. mfr456
    mfr456 Karting
    May 3, 2015
    136
    Melbourne
    This is great ! Thank you
  10. cromwrima
    cromwrima Rookie
    May 31, 2023
    39
    Anyone have any pictures of the difference in light output at night?
    I can't imagine it'll be noticeably better as the projector lens in the FF are shocking, and that's the main cause of the problem.
    I walked past a 599 the other day and the headlights on that seemed much, much sharper with a clear cutoff and a nice colour band on the edge of the beam, and that's an older model than the FF! Seems like they went backwards a bit with the technology.
  11. Jackyli
    Jackyli Rookie
    May 27, 2024
    3
    Jacky Li
    The most useful comment ever! Thank you all for sharing your information! I am the new owner and will be the last owner of my 2014 FF
    ANOpax likes this.
  12. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,354
    The Netherlands
    Welcome to the forum Jacky.
    Glad to hear that you’re enjoying the FF and don’t plan to let it go. We feel the same about ours.
    Jackyli likes this.
  13. Jackyli
    Jackyli Rookie
    May 27, 2024
    3
    Jacky Li
    I am trying to change the Xenoe bulb to D1S Led Bulb, after completion, will let you guys know the result. It may have error code, the technician said that to me.
    ANOpax likes this.
