FI/Ignition Troubleshooting in Seattle | FerrariChat
Discussion in 'Northwest' started by jcurry, Nov 21, 2021.
  1. jcurry
    24,088
    In the past
    Jim
    Any recommendations for fuel injection and ignition troubleshooting for a 1983 308GTSI/QV. Seattle area, preferably north.
  2. Vonbarron
    Vonbarron Formula 3
    2,261
    Westside Mofo
    S B
    What are the symptoms
  3. jcurry
    24,088
    In the past
    Jim
    Cold starts fine, but I don’t get a fast idle. After a few minutes the idle will increase. There is also slight ‘tic’. No noticeable change in rpm, but just seems like a plug is not firing sometimes.
    Runs strong and even without any stumble, but even when cruising there is still a ‘tic’.
    When hot and at idle will run rough and am even getting what seems to be a full bank intermittently cutting out. Rev the engine and all returns to ‘normal’ (‘tic’ still there).
  4. jcurry
    24,088
    In the past
    Jim
    Injectors are essentially new. Battery is new.
    Air pump is disconnected (no belt) as is egr valve. Been that way since before I bought it 8 yes ago.
  5. Vonbarron
    Vonbarron Formula 3
    2,261
    Westside Mofo
    S B
    Checked the vacuum lines to the ignition boxes?
  6. Vonbarron
    Vonbarron Formula 3
    2,261
    Westside Mofo
    S B
    I had similar symptoms, mine traced to a cracked hose in the hidey hole of the trunk and a crank sensor going out, I replaced two crank sensors for good measure and has been fine since
    jcurry likes this.
  7. windsock
    windsock Formula 3
    1,153
    Seriously Jim. You haven't given me a call.
  8. jcurry
    24,088
    In the past
    Jim
    Well .................... somehow I had the impression that you were disinclined to work on these 'older' cars, otherwise I never would have started this thread. I'll contact you.
    SeattleStew and f355spider like this.
  9. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I was just about to post - please contact Mark G.
    He will take care of that issue.
    Glad to see Mark already chimed in.
