FIAMM 2000 series Air Horns | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by 635CSI, Dec 2, 2013.
  1. 635CSI
    635CSI F1 Rookie
    Jun 26, 2013
    3,046
    London UK
    Graham
    I am looking at fixing up a pair of these.
    I have the correct paint colour for the trumpets but rather than masking I would like to remove them from the cast body of the horns.
    I don't know though if they unscrew or pull off, without using too much brute force I have tried both but to no avail.
    Does anybody know the correct technique before I try too hard and break something?
  2. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    #2 El Wayne, Dec 2, 2013
    They unscrew. See the threads on these horns:
  3. El Wayne
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    #3 El Wayne, Dec 2, 2013
  4. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    You loosen the large jam nut then unscrew the trumpet by hand.
    If there is a word of caution, the jam nuts are nickle plated brass, handle them carefully and with the correct size wrench.
    john
  5. 635CSI
    635CSI F1 Rookie
    Jun 26, 2013
    3,046
    London UK
    Graham
    Brilliant advice, thank you very much
  6. haudimal
    haudimal Rookie
    Dec 10, 2007
    30
    Ralph Bauer
    just a few years later I have the same problem removing the trumpets.
    It seems I have a different version because there is no nut just some pice of plastic.
    Any idea how to get the trumpet out of the body?
    Thank you!
  7. John Vardanian
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    Stefan, if yours are pitch tuned by screwing the trumpets in/out, the trumpets would screw out like the earlier 60's version-- at top of this thread.
    john
  8. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    Those are not vintage Fiamm horns. There are some modern reproductions that are incorrect for a vintage Ferrrari. They appear to be unserviceable, with the trumpet held into the body with a plastic grommet and the back of the horn is crimped onto the main body casting. Correct original Fiamm horns are not very hard to find or are very expensive. Do some searching on ebay and you can find a set for a reasonable price.
  9. haudimal
    haudimal Rookie
    Dec 10, 2007
    30
    Ralph Bauer
    Thank you John and Brian - and I´m afraid Brian is right. I was able able to turn the trumpet but there is no thread. And it seems impossible to pull them out of the case.
    Just out of curiosity do you think the plastic cover is repro, too?
  10. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    Those horns are real Fiamm horns. They are just what Fiamm is now making using cheaper modern manufacturing methods. They have the right look and sound, but are not identical to the old period horns. They are fine if you want the air horn sound, but are not correct for a proper vintage restoration.
    turbo-joe likes this.
  11. haudimal
    haudimal Rookie
    Dec 10, 2007
    30
    Ralph Bauer
    Ok, thank you. Now I got it - real Fiamm horns but not real vintage Fiamm horns.
    And you're absolutely right, they really sound like the old horns.
