Fiberglass 308 Questions | FerrariChat
Discussion in '308/328' started by Cenzoooo, Jul 12, 2006.
  1. Cenzoooo
    Cenzoooo Karting
    Jul 20, 2004
    130
    Queens, NY
    Vincent L
    I just received my spare tire retainer bolt for my 76 308. I go to put it in and find there's no place for it to screw into... I recently found out that only the 76 model had a zippered vinyl cover for the spare, the zipper is currently busted on mine. Did the fiberglass car have the retaining bolt at all or did they just have the vinyl cover?
    I took the car out for a drive today and really let it stretch its legs. I noticed at the top of 3rd after 5500rpms it started missing. I kept running it through to redline and it kept missing. Shifted to 4th still full throttle, and it did it again at about 6000 through redline. Is it worth it to have the point redone, or go with the Forza ignition? The car was pulling really strong and then felt sluggish and was surging about 6000rpms, I feel like im loosing out on a lot of power up there.
  2. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,448
    Canada
    Newman
    I would check the points and readjust. Mine has the single distributor and revs to 7500RPM fine. As for the spare, the 77 euro glass cars also have the zippered flap with a minispare rather than the full size US version. My boxer has no hold down either and no provisions for one.
    P.
  3. 308 GTB
    308 GTB F1 World Champ Rossa Subscribed
    Feb 7, 2002
    11,718
    New Jersey
    Barry Wolinsky
    My 1976 fiberglass GTB has no hold down bolt or provision for one. I agree with Paul. Your distributors and points need adjustment.
    Barry
  4. 308 GTB
    Feb 7, 2002
    11,718
    New Jersey
    Barry Wolinsky
    Full size spare for the North American fiberglass GTBs.
  5. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,380
    Houston, Texas
    Bubba
    So mail me the bolt....LOL!
    Agree that the miss is igniton, maybe points maybe one of the coils...investigate.......
  6. BigTex
    Dec 6, 2002
    79,380
    Houston, Texas
    Bubba
    Mine goes to 10,500, when I miss a shift.....;)
  7. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,485
    Austin, Texas
    Michael C
    I don't know much about mechanical stuff, but a friend of mine has a 76 'glass 308 and he told me that he did away with all the points and upgraded it will stealth modern technology that looks original.
  8. 308 GTB
    Feb 7, 2002
    11,718
    New Jersey
    Barry Wolinsky
    Ahhh! The pleasures of no rev limiter!
  9. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    The early '77 GTB steel cars have a zipper cover as well.
  10. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Guildford, Surrey UK
    Paul Deslandes
    My '76 fibreglass has the zip cover and a wheel retaining strap to hold it down. There is a metal bracket that the strap goes through on the bottom of the wheel well. Being a UK model it has the small 'get-you-home spare'.
    Another thing to check re the ignition misfire are the plug extenders. Mine were all over the place, some open circuit, high resistance or dead short. They should measure about 1200 ohms but if they're all about the same and less than 2k they're probably ok. IIRC there are black ones which are non-resitive and red ones which are. After replacing mine and resetting the points my misfire went away and it revs right up the range in all gears.
  11. pete04222
    pete04222 Formula Junior
    Nov 1, 2003
    613
    Maine, USA
    Peter Cyr
    For the broken zipper the best thing to do would be to remove the cover and take it to a place that does custom boat upolstery. I did that on my trunk cover and got a heavy-duty marine grade zipper installed for $30.
  12. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Like Paul says, check the plug extenders and ignition wires as well as the points and timing advance. Points require maintenance but they are quite good when all is well. Car should redline no problem.
    Birdman
