Figures... | FerrariChat
Figures...
Discussion in '365 GT4 2+2/400/412' started by dstacy, Jan 10, 2014.
  1. dstacy
    dstacy F1 World Champ
    11,998
    GMT -5 & GMT +1
    Dave
    Went for a quick spin and I get one of the alternators lights glowing on the dash. Nice! Ok, easy fix. Then I noticed it is the lower alternator light glowing.
    It had to be the lower one right? Why couldn't it be the upper one which is easy to get to and can be changed out in less time than it takes to finish a martini?
    <sigh>
  2. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,257
    MA
    I feel for you brother! When my alternator light came on, it also was the lower one! :(
    The good news is that the car will function on one alternator if you are judicious in using lights and air conditioning. You will be able to drive it to the shop no problem. I suppose you can do it yourself but getting that thing out and then back in is a bear and one where I didn't mind paying the shop labor for it.
    As long as they both have to come out, may as well have the top one rebuilt too.
  3. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Yeah, it looks like the tie rod needs to be unhooked to drop that bugger.
    I'm figuring that most of our upper units were rebuilt at one time & it's only a matter of time when the lower one needs attention.
  4. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,376
    Central NJ
    Dave,
    The reason the lower one takes so long is because you were drinking a martini while removing the upper one :D.
    Regards,
    Art S.
  5. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Alternator 'failure' is usually corrected by just changing the brush module on the back side. Parts available for $20-25.
    Yeah, the belts are the real issue to put them on in correct order and don't adjust the lower alternator belt until all belts are in place....my experience.
    Ken
  6. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    I put a new clutch in my car by myself, big project but doable, however after looking at this project I think that bad boy is going to get changed out by someone other than me.
  7. Ak Jim
    Ak Jim F1 Veteran
    9,624
    North Pole AK
    Sometimes it's worth paying to have it done.
  8. SouthJersey400i
    Mar 14, 2007
    1,679
    Ken Battle
    Complete belt change took me 9 hours over two weekends the first time (getting correct belts); I think I can do it in under 4 now. The lower alternator is just part of that job.
    I'm in the middle of the drive shaft tube bearing job and two weeks ago I was ready to load it on a flat bed, but now feeling better as its starting to go back together.
    Ken
  9. dstacy
    11,998
    GMT -5 & GMT +1
    Dave
    yep that shaft is quite a job
