fill pits in camshaft | Page 2 | FerrariChat
Discussion in '308/328' started by bertspeed, Jan 3, 2017.
  1. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    New cams from Cat Cams in Belgium may be cheaper (plus you can choose from several profiles and get upgraded springs to match.)
  2. enzo52
    enzo52 Karting
    Aug 14, 2008
    131
    France, Paris
    Depensadie Seraphin
    #- steel billet camshafts#FOR COMPETITION APPLICATIONS ONLY. Following details must be verified: - the camshafs must turn smooth in the cylinderhead, provide free travel by machining where needed - distance between valve seal and retainer at full lift must be 0.6mm at least - minimum valve spring travel of 1.0mm at full lift must be provided - distance between valve and piston 1.0mm (pref. 1.5mm). check 5-15° before TDC on exhaust, and after TDC on intake#original valve spring info is not available#ONLY for dirt track applications and pro street use with adjustable engine management or carburettors
    Enzo52
  3. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I think that is a legal disclaimer for their higher lift cams. They have original profiles as well.
  4. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    As Brian Crall has said, most Camshaft Machine shops should be able to handle it. I believe they re-weld and re-grind the journals. When it comes to the Cam Lobes, depending on the profile, that too can be done the same way. I have had them done in Australia, Germany and I believe that a lot of the Camshaft Profiles were developed here in the USA for performance engines. High Lift Camshafts may pose a problem, but it is best to ask the Machine Shop, I am sure they will suggest what you should do. As you are in the UK, there are a bunch of places who do Camshafts from Ford BDA's and Lotus for example.
