Filling Up in CA | FerrariChat
Filling Up in CA
Discussion in '456/550/575' started by Joel Delman, Jul 18, 2021.
Tags:
  1. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    Hi All,
    No, not a post to vent about our ridiculous gas tax here in CA, but rather about the compatibility of my 575 with (seemingly) every CA emissions compliant pump I've been too so far...
    Is it just my 575 (a 2004), or do these anti-vapor pumps not work well with the filler on our cars? And is there a trick to making a fill up easier? I have had to let gas trickle in, and work to find / hold the "sweet spot" to keep gas flowing.
    Any advice appreciated, thanks!
    NorCal360 likes this.
  2. vandevanterSH
    vandevanterSH F1 Rookie
    3,440
    AR
    Stephen Van Devanter
    I had similar problem 12(?)years ago. Quite annoying on a road trip, stopping at several dealers to sort it out. The final solution was to replace the charcoal filter in the evap system.
  3. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    Thanks, I'll look into that as a possible fix
  4. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,488
    Los Gatos, CA
    Eric
  5. Mirek
    Mirek Formula 3
    1,524
    Los Angeles, CA
    Mirek
    I usually have to try multiple angles as it seems that the pump cuts out intermediately due the perceived pressure. This happens on a lot of my newer cars here in CA and even in NY. Some worse than others but the Ferrari can be the most “sensitive” to this. I just grin and bear it, meanwhile my car is in the shop again.
    Joel Delman likes this.
  6. Tarek307
    Tarek307 Formula 3
    1,349
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    Had same issue with my 360 it drove me nuts, then my 458 sometimes until i found a little rubber gadget you put over the filler then stick nozzle in that lets the pump keep going. The 550 has been fine and easy to fill up
  7. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    Interesting, just read the auction comments... Seems like he had quite a few issues with the fuel filler, and in the end was advised to "do it slowly" :)
  8. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    I was actually thinking that some sort of rubber "seal" could be a fix... Would you have a link to the gadget you found?
  9. Tarek307
    Tarek307 Formula 3
    1,349
    Tarek Salah
  10. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
  11. Impounder
    Impounder Karting
    Aug 6, 2010
    172
    Laguna Niguel, CA
    Have had this issue for years. Final solution that seems to work 95% of the time.
    Flip the nozzle upside down and leave a small gap in the connection to let the pressure release. And make sure you are filling up when cold.
    Any other time I still have problems.
  12. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    Thanks... Crazy to see how many others face the same issue. One more reason to be sick of CA I guess.
    I ordered the rubber seal mentioned above, will report back after I have had a chance to give it a try
  13. SteveVT
    SteveVT Karting
    Nov 30, 2019
    107
    Vermont
    Steve
    Joel- I am having a similar issue with my 04. How has the rubber seal worked out?
  14. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    Steve,
    Unfortunately the rubber seal didn't work at all for me... I did find the "hold the filler upside down" technique helped somewhat though, at least at one station.
    Best,
    Joel
  15. Steen Jensen
    Steen Jensen Formula Junior
    Mar 29, 2009
    304
    Calgary , Alberta
    I have the same problem with my 04. It "fixed itself" for awhile but the super slow fueling is back.
    Almost certainly the charcoal cannister or solenoid. This is a problem that plagues many car types as a quick check on youtube will affirm...
  16. SteveVT
    SteveVT Karting
    Nov 30, 2019
    107
    Vermont
    Steve
    Good to know- thanks. I've found the hold the filler upside down approach works sometimes, but not others. Looks like replacing the charcoal cannister and/or solenoid might be the best long-term solution.
  17. root
    root Formula Junior
    489
    Bay Area, Ca
    I had similar problem in my 2000 Jaguar XK8. Replacing the charcoal canister and vent valve solved the problem. There are two fuel vapor recovery systems. The Onboard Refueling Vapor Recovery (ORVR) systems which are carbon canisters in cars since the early 2000s to capture the fuel vapors evacuated from the gasoline tank before they reach the nozzle of a gas pump. The fuel vapors captured in the carbon canisters are then returned to be combusted in the engine when the car is in operation or vented out through a vent solenoid. The other recovery system is the Stage 2 Gasoline Vapor Recovery which returns the vapors from the car's fuel tank through the filling hose back to the station's fuel tank. When the canister is clogged or vent solenoid is stuck in the closed position pressure builds up inside the tank during fueling preventing more fuel from getting dispensed. The 575 should have a secondary vent hose from the tank back to the filler neck which should provide pressure relief by utilizing the station's Stage 2 recovery system. I'd check the vent hose for blockage and check the canister and vent solenoid for proper operation.
  18. TheMayor
    107,754
    Vegas baby
  19. NorCal360
    NorCal360 Rookie
    Jun 8, 2023
    1
    California
    Sean Wallentine
    I have this problem with both my 2001 360 and now with my 1987 328. Both are a nightmare to fill up. Won't keep the seal and the handle pops, even when I'm manually filling. It pops in my hand. Embarrassing to struggle filling up my exotic cars. I look stupid out there. LOL
  20. Ferrari55whoa
    3,488
    Los Gatos, CA
    Eric
    Can’t you just hold the black “accordion” back towards the handle while filling and then it keeps going?
    I do that on my portable can and also the motorcycles?
  21. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    Turned out to be a veyr easy fix, my mechanic just replaced the charcoal canister that's part of the system... Not too expensive, and never had an issue at the pump since.
  22. vandevanterSH
    3,440
    AR
    I had the same problem on a cross country drive to CA 15 years ago....what a PITA! ~30+ minutes for a fill up. Stopped at two dealers, no better, finally stopped in Dallas on the way home and charcoal filter changed; no problem since. I thought at the time that perhaps "topping off" the tank put raw gas in the filter and damaged it but the fact that the problem hasn't recurred makes me think that there was a manufacturing issue with the filter.
  23. Joel Delman
    Joel Delman Karting
    May 4, 2021
    156
    Los Angeles
    Joel Delman
    The filter gets "filled up" over time and can't absorb more, they need to be changed fairly regularly, every few years (unless the car is rarely driven, but then you're bound to have bigger issues:)
  24. Aerosurfer
    Aerosurfer Formula 3
    1,973
    Indianapolis
    Nick
    Coincidentally this week I decided to dissect my charcoal cannister. There isn't much to it.
    On the early 456 cars, it's not even fully sealed from the environment. The top can pop off. I found a padded top piece thst is supposed to push down onto the charcoal by spring pressure. On mine, over time the springs had done a 180* and were buried in the charcoal.
    The charcoal itself was lumpy like cat litter. I poured it out and broke it up and let it air out, if thst matters. Had read someplace the charcoal doesn't actually go bad.
    The bottom was a similar foam and wireless that separated it from the purge lines. One line only vented in and the other was a 3 inch plastic tower thst stuck into the charcoal. It was full of bits and held back by a piece of foam. There were no cracks in the container, so I cleaned it all up and reassembled. Will make new lines for the purge valves. As well as clean them. They electrically functioned, so I suspect they work as designed, but are easy enough to reach if I replace them in the future. I have a secret santa sending me a used one, just to try and discern if there is any different between 0280142150 (early) and 0280142300 (later years)
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Mirek, Ferrari55whoa and Joel Delman like this.
  25. Aerosurfer
    1,973
    Indianapolis
    Nick
    It looks like activated charcoal is cheap and abundant for aquariums. I'll pick up a few pounds this weekend from petsmart and compare consistency, before I reinstall it on the car
    Ferrari55whoa likes this.
