Final Drive gearing change? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by samtheclip, Jan 3, 2005.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Upon further reflection, I only want an 'overdrive' 5th gear for touring. Want the other gear ratios kept the same for acceleration.
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    As the speedo is driven off the output shaft that drives the ring gear, and as the transfer gears are at the input side, changing the gear ratio of the transfer gears has no bearing at all on the speedometer, it will still be acurate.
  3. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    My Fmech told me the drop gear kit he can get which comes from Italy costs about US$2500.You can pick from the ratios you want.
  4. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    [/QUOTE]
    You can drop your revs by increasing your rear wheel and tire size. This has the same effect of changing your final drive gear. [/QUOTE]
    Paul, I was talking about the larger size tires will need a seedo adjustment, since the output shaft will now turn slower with the larger circumference tires.
  5. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    So much for a quick response on this...
    You can get a drop gear kit from me, which includes one drop gear ratio (as opposed to a set of eight if you were racing various tracks), which is a set of three gears, a lightweight magnesium housing, and all assorted spacers, bearings and nuts to do the install.
    Cost is $3,799. Please email me (or call) for ordering, shipping and delivery details.
    I would enjoy offering a substatial discount for a group order. Five kits saves $300 each, 10 kits saves $800'
    Best regards,
    Rob
  6. MRFOTOS
    MRFOTOS Karting
    May 26, 2003
    232
    Maui, Hi
    Where does this housing go?
    There is not much space over there, and it cant go any lower or it will scrape on the ground.
    Do you have any fotos to enlighten us?
    Thanks for not forgetting about us.
    Mark
  7. aasprou
    aasprou Rookie
    Jan 29, 2005
    9
    Mrfotos, the 18 look fab, did you do any suspension mods, I also noticed that
    discs and calipers are diffrent too?. do the 18's slow the acceleration?
    finally are there any clearance problems?.
    stas.
  8. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    #33 Sloan83qv, Feb 21, 2005
  9. JTranfield
    JTranfield Formula Junior
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    This is interesting because in my 77 I am looking for more top end. Even driving sedately keeping up with Atlanta traffic I still constantly hit the rev limiter in 1st and 2nd and at 90 it revs way to high for me. As a matter of interest do you guys go much above 100 at all? I have hit the cut out in 4th lots of times and it doesn't seem that fast, there is no way I can imagine the cut out in 5th being 150 more like 125 or so. I am running 16 inch rims so maybe that is having an effect?
  10. rexrcr
    rexrcr Formula 3
    1,578
    Kalamazoo, MI
    Rob Schermerhorn
    That's the one!
    Rob
  11. stratos
    stratos Formula Junior
    Dec 9, 2003
    639
    Switzerland
    These gears use straight-cut teeth. They must be horribly loud and whinning...
  12. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Sweet for the track. I assume pretty hard on the ears on the street after an hour of highway driving. Paul?
  13. stratos
    Dec 9, 2003
    639
    Switzerland
    #38 stratos, Feb 22, 2005
  14. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    Let's put it this way between the Borla and straight cut gears you will never sneak up on anyone or for that matter sneak away.
    At 40 mph's the gears are like twin superchargers running at 10,000 rpm's it gets quieter around 100 mph. So I just go faster.
    paul
  15. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    :) LOL :)
    Thanks for the MUCH NEEDED smile. Looking outside right now at 3+ feet of snow :(
  16. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    #41 Sloan83qv, Feb 22, 2005
    Steve,
    Looking outside and the sand on the Beach is as white as Snow and more then 3 feet deep.....I feel your pain!
    Photo says it all!
  17. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Utah
    me too! The car needs another gear to comfortably cruise the hwy.
  18. TURBOQV
    Mar 6, 2003
    838
    NV and Utah
    i feel your pain!
  19. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Forgive me if I'm out on a limb here. My motor is out and I dont know how much room we have on that side, but what about a two speed gear train you could shift manually under the hood to choose from "road or track"? If there was room to extend an outer gear set far enough for a sliding coupler at the top gear to engage inner, or outer set, you could have the best of both worlds.
  20. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    #45 enjoythemusic, Feb 23, 2005
    Pain, truth? You can't handle the pain truth! ;)
    Think about it... what oil has a pour rate at NEGATIVE 56F??? Let the oil debate begin ;)
  21. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    Olive oil?
    Sorry to all did not mean to hijack or get off track with weather issues.
    Paul
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,874
    The twilight zone
    That is what I'd like to have, nice quite helical gears so the engine drone isn't replaced with gear whine.
  23. stratos
    Dec 9, 2003
    639
    Switzerland
    Then you need to cut your own gears and get yourself a big cascade gear cover as per Michelotto cars. All parts can still be sourced in Europe, either original or replicas. You should count around 1000$ for the cover and the same amount per gear, total cost 5000$. Each alternative ratio will set you back another 4000$. They can be changed in less than 30 minutes by anyone and will give a top speed from 100mph (with hellish acceleration) to 160mph or anything you want.
  24. enjoythemusic
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Ditto. My apologies too. i'll hush up now.
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,874
    The twilight zone
    Yeah, it’s a lot of work, and it hasn’t made the top of the list yet. I looked at is briefly and I’m pretty sure I can just buy pre-cut gear blanks, machine them to fit and send them out to be hardened. If it can be done this way, I think blanks are under $200 each plus about 2 hours of shop time and heat-treat, so maybe $1000-$1500 for the set. The cover can be machined from billet for $500-$1000. Prices would be less if more than one set are being made…..I’ll have a proper workshop in a couple months, so this might be my winter project.
