Finally upsized my 328 tires..... | FerrariChat
Discussion in '308/328' started by donald, Jul 2, 2005.
  1. donald
    donald Karting
    Aug 11, 2004
    197
    Dallas, Texas
    Don
    I decided to upsize my 328 tires and I am very pleased with the result. They looks better and the car definetely drives and handles much better. I went with Yokohoma AVS and wish I did this sooner!! No rubbing either.
    Big thanks to this site for the info regarding upsizing 328 tires. Now if only the a/c would blow colder in this hot Texas heat......
  2. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Yep, it sure DOES make a handling improvement. From what I've seen on the board, probably AT LEAST nine out of every ten folks who make the change are happy they did. I'm certainly one of them.
  3. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Can you please post the exact tire specs? Also, approximate cost?
  4. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    You put the stock rear tire size (225/50-16's) on the front and put 245/45-16's on the rear. This properly maintains overall diameter while putting additional rubber into your contact patch. Tire Rack prices for Yoko AVS ES100's are $97 per tire for the new rears and $86 per tire for the new fronts.
  5. donald
    donald Karting
    Aug 11, 2004
    197
    Dallas, Texas
    Don
    mcharness posted the sizes I used and the prices listed from Tire Rack are also about what I paid.....
  6. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Thanks for the follow-up, guys.
  7. maquino
    maquino Karting
    Jun 22, 2005
    219
    After reading this thread, and since my 328 needed new tires, I went to the local WheelWorks and inquired about the Yokohamas. Spent some time talking about options with the staff, and finally went for their recommendation: Bridgestone Potenza #RE750. That's a pair of 225/50R16 ($132.99 ea.) and a pair of 245/45R16 ($218.99 ea.). For the four tires together WheelWorks then deducted a total of $117.96 to match their Tire Rack prices.
    I agree that the new tires make for a noticeably nicer driving experience. :)
  8. wilkie
    wilkie Karting
    Apr 15, 2005
    100
    L.A., CA
    Wilkie Cheong
    And this is with the stock wheels? Sh-t, I just replaced my worn out tires with the stock sizes. Wish I woulda stumbled upon this thread a few days earlier! Now I gotta wait another 20K or so miles.
  9. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Well, you *could* just keep those existing front tires for spares, and put your new rear tires on the front rims, since that's the way it works out. Then just buy a pair of new rears in the 245/45 size. Or if your existing fronts wear out first, start the process at that time.
  10. wilkie
    wilkie Karting
    Apr 15, 2005
    100
    L.A., CA
    Wilkie Cheong
    Hmmm, that's true. Maybe I can unload my almost-new front tires . . .
  11. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    I think I am going with the Potenza RE750. Anyone have pics of there car with the upgraded sizes on it. Don't want it to look ballonish or have the tires stick out. Will put 225/50/16 on the front and 245/45/16 on the rear.
  12. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    I too am having the debate about putting the wider tyres on my 328 & I can see a few pros & cons that I wonder if anyone has an opinion on.
    However, firstly, where people have done this and report good increases in grip levels I wonder how old were the tyres you took off the car? As tyres get older they get harder & so it would be normal for new tyres to feel much better - the question I wonder is how much of the improvement is down to the extra width & how much is just down to the fact that the tyres are newer, possibly softer and certainly of a new & better design than the old ones?
    On the Pro's side of the equation I think the wider tyres would possibly look better as long as the sidewalls arn't bulging out too much as someone else mentioned, and secondly they should provide better grip and better braking simply because there is a bigger contact patch.
    On the possible negative side I could see that there might be a degradation in wet weather grip (vs standard sizes) - not that I drive my car in the wet much if at all. Secondly I would imagine that slow speed maneouvering is harder work and thirdly I wonder if there might be any long term negative effects from the extra work being put into the steering and suspension systems. Then on top of that there must be an increase in weight though I'd imagine this isn't very much.
    Any thoughts?
    I.
  13. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,128
    E ' ' '/ F
    Snike Fingersmith
    #13 GrigioGuy, Jul 26, 2005
  14. maquino
    maquino Karting
    Jun 22, 2005
    219
    An additional benefit of the Bridgestone Potenzas is that they have those small "wheel protection" rubber ridges on them right next to the edge of the wheel. In short, if you are parallel-parking and get too close to the curb, you will rub against this rubber ridge (enough to sense it) instead of chewing up the edge of your $$$$ Ferrari wheel.
    Some modern tires have this (great!) design feature. I don't know whether the Yokohamas have it or not. I do know that the original GoodYears did not have it.
  15. hanknum
    hanknum Formula 3
    Nov 1, 2003
    2,050
    Santa Barbara
    Henry
    #15 hanknum, Jul 26, 2005
