"finding" the pin code | FerrariChat
Discussion in '348/355' started by gus355, Oct 30, 2011.
  1. gus355
    gus355 Formula Junior
    Aug 3, 2011
    569
    B.C. and WA
    Soooo... I had a thought - if one were a little adventurous - and lucky - they could try a stab at guessing the pin code...
    I figure it's better odds than most lotto - and with a $500 prize!
    1 in 10000 ain't that bad, maybe use a program to generate the numbers in random order or just enter them in sequence - front to back or back to front - maybe go half way then start from the other end?
    What do you think?
  2. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    When I bought my car it came with 2 black remotes and 1 red remote. Only one black remote worked. I found a pin code that was different than the original so I tried to put it in. This was such an ordeal even with the correct pin code it took 1.5 hours. This is mostly due to having to go through most of the steps only to find out it did not work. I do not think most would have near the patience.
