Fiorano Handling Package (F355) | Page 5 | FerrariChat
Discussion in '348/355' started by Rothbauer_Racing, Sep 11, 2008.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    I highly doubt anyone successfully fully retrofitted an FHP kit onto a 355 and I don’t know about it. Too much hard-to-find details and no way this was all known 10-20 years ago, not to mention availability of the parts. Point is, if a 355 has all of these parts, it came from the factory that way.
  2. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Ken, it's also interesting to note that the "sporting" geometry setting was not available for the USA, Canadian and Australian markets. I wonder what camber, caster, toe-in and ride height settings were used for those markets.
    If you manage to get the few missing parts you need for your planned OEM FHP retrofitting, will you use the listed geometry setting?
  3. ShineKen
    20,202
    Southern California
    Nostradamus
    This "confidential" document (notice the writing along the sides) was issued Feb 1999. I believe they are generally stating FHP options were not available on U.S, Canada, and Australian cars, hence the geometry was also not given to those cars. Considering Serie Fioranos came about the second half of 1999 in the U.S, this document was probably pre-mature in making that statement.
    I will aim for these spec/geometry as best as I can, because I am eager to experience FHP as intended. I am surprised by -2.3 degree rear camber. It better be good :).
  4. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    That would be a good choice.
    For comparison, here are the suggested basic setting data for the F355 Challenge as it appears in the Ferrari F355 Challenge Technical Regulations...
    stormrider96150 and ShineKen like this.
  5. Gooselander
    Gooselander Karting
    Jul 27, 2020
    62
    Happy to post it, I have searched for Ferrari documented information on the Fiorano Pack for years, I'd never seen anything like this document before.
    308 GTB, ShineKen and MAD828 like this.
  6. ShineKen
    20,202
    Southern California
    Nostradamus
    I need to make a correction. Uprated rear sway bars currently hits lower spring perch on dampers, not suspension arm.
    355 challenge rear lower forks are same as standard, BUT spring perches sit higher on the damper due to very short challenge springs.
    Illyria likes this.
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,956
    Richmond
    Pete
    With which springs - standard or FHP? And which ride height? Those will affect spring perch location.
  8. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    Superformance sell the straight on type rear forks as well
    ShineKen likes this.
  9. ShineKen
    20,202
    Southern California
    Nostradamus
    FHP springs. They are taller than standard springs. Relatively standard ride heights. Not slammed.
    *hits under hard turning
  10. ShineKen
    20,202
    Southern California
    Nostradamus
  11. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,472
    Los Angeles
    It's gotta be to maintain correct suspension geometry at the lower ride height of the challenge cars
  12. ShineKen
    20,202
    Southern California
    Nostradamus
    But challenge cars have standard rear lower forks.
    Rifledriver likes this.
  13. Rifledriver
    37,367
    Ch cars had standard forks but were set at very negative camber. Often had no shims.
    Targatime likes this.
  14. Rifledriver
    37,367
    At my dealer we did it to several cars when they were still nearly new. I remember the last one we did we had real trouble getting the adjustable sway bar links.
    One story we got from the factory and sounded legit was the package was offered to get rid of existing stocks of parts they really didn't want to inventory anymore.
  15. Rifledriver
    37,367
    #115 Rifledriver, Aug 2, 2023
    Standard 355 to my recollection. Running those set up numbers it would have violated bumper height restrictions so Ferrari could not condone those numbers. We did do a lot of experimentation on suspension set ups and kind of had our own for street use. Few wanted to go very low and if camber was very negative they would eat tires on the street. We did set the front a little lower on cars that did a lot of high speed use. We got good feedback on it improving the stability at very high speeds. It all depended on how it was being used.
    308 GTB likes this.
  16. Rifledriver
    37,367
    The internal pressure regulator was set to lower pressure.
  17. ShineKen
    20,202
    Southern California
    Nostradamus
    Adjustable sway bar links were only on challenge cars. Not part of the FHP kit.
  18. C'dwic
    C'dwic Formula Junior
    Apr 23, 2021
    493
    France
    Thanks to all, missing the forks since yesterday… I didn’t know they were different.
    It’s not given the forks for some steel….
    Will be installed next small check.
    I think my 355 will be completed as factory
    Gooselander likes this.
  19. C'dwic
    Apr 23, 2021
    493
    France
  20. C'dwic
    Apr 23, 2021
    493
    France
    Thanks to the Cat ! Owner is Ken
  21. ShineKen
    20,202
    Southern California
    Nostradamus
    C'dwic likes this.
  22. Rifledriver
    37,367
    I installed a few sets of them along with the front CH shocks which the cars really need.
  23. GaetanVDK
    GaetanVDK Karting
    Oct 20, 2015
    103
    BRUSSELS, BELGIUM
    GAETAN VDK
    In today's market, how much is a F355 GTS with Fiorano Handling Pack (FHP), eurospec, manual, grey with 40.000 KM worth do you guys think?
    I wasn't able to find any reference points on BAT as they weren't sold in the US... i thinking of buying one.
    Thanks for the advice :)
  24. C'dwic
    Apr 23, 2021
    493
    France
    Hello Gaetan From France, F1 or manual box ?
    I imagine F1, it exists very very few GTS FHP with manual box.
    Tell us please
