Fiorano Handling Package on 575M or not? | Page 3 | FerrariChat
Discussion in '456/550/575' started by Passion_of_V12, Mar 2, 2025.
  1. Passion_of_V12
    Passion_of_V12 Karting
    Feb 15, 2025
    55
    Denmark (Europe)
    J.A,
    What hvad you guys paid for these Brembo 6 front/4 rears?
  2. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,867
    France
    It was about 20 years ago, so I would need some research in old files to find not really relevant information :(
    Passion_of_V12 likes this.
  3. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,957
    MO
    Omar
    #53 Auraraptor, Mar 11, 2025
    Regarding pads:
    The OE Ferodo FM1000 on the 575 and 512TR.
    Porterfield R4-S on the BMW which shared the front caliper with the 512TR and the rear caliper with the 575. Not sure if the R4-S is made in the size for the 6 piston calipers but I know its made in the F50 and rear sizes.
    If your asking $$$, the 355mm F/345mm rear are NLA now. Good luck finding any let alone for the previous market rate (around $8000-$9500 pre-COVID). I do have the core parts to make one last 345mm rear kit if someone really wants as I bought all of Brembo's left over stock when they went NLA.
    Brembo still offers the larger 380mm Front/Rear kit but I think that goes for a bit more $$$. Never optioned the price out for it as I wanted the period correct 355mm version.
  4. tazandjan
    39,150
    You need 19" wheels for the 380 mm rotors, I believe.
  5. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,867
    France
    Actually you don't, I had standard wheels on my 575.
    Regarding fitting 380mm to the rear (as seems to be the only available option now), I wonder what it would do on the front/rear brake balance (even though apparently it's 6-pot front and only 4-pot rear).
  6. Auraraptor
    Sep 25, 2002
    13,957
    MO
    Omar
    I did all the calculations for the different combinations when I was trying to decide.
    Long story (and a lot of math) short: both the 355mm Front 6 piston / 345mm Rear 4 piston and the 380mm front 6 piston and 380mm rear 4 piston brake biases are excellent for the 575.
    You can even get away with the the OEM 330mm Front / 345mm Rear 4 piston setup and keep the brake balance very good, though you must use the C caliper and not the P caliper to do so. This is only true for the 550/575. The 456 requires the P caliper rear 345mm setup to work w the OEM 330 front.
  7. poljav
    poljav F1 Veteran
    9,976
    SF Bay Area
    Pol J.
    I did the same recently, MSW steering ECU/rear sway bar and now on the hunt for the rear springs. I also found 18 OEM Barchetta wheels, its now mounted with HE spacers. Did you install the ECU, bar and springs at the same time or installed the springs later? Be curious how much of a difference the drive is with and w/o the springs. I will say just having the ECU and bar, the drive is night and day from stock.
  8. Auraraptor
    Sep 25, 2002
    13,957
    MO
    Omar
    I honestly think the springs are the least important part. The swaybar and steering controller being the most important (add suspension controller if you have an early 575).
    It shoulds like they made another batch of rear springs (HGTC) so they should be available even if vastly overpriced.
    H&R makes aftermarket springs though I dont have their specifications
    Passion_of_V12 and poljav like this.
  9. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,867
    France
    My bad, I actually had 355/6-pot front and 345/4-pot rear :oops:
    https://www.ferrarichat.com/forum/posts/148648987/
  10. white out
    white out Formula 3
    Mar 3, 2010
    1,287
    Fronts: $4895 & Rear: $4195
    380mm rotors under an 18" wheel is common (Murcielago with CCB), but it is tight and will not fit under all 18" wheels. There are cutaways for measuring the brakes within your wheels to ensure clearance. Feel free to message me and I can send you the PDF.
    I am running the same fronts on my Viper (and for lack of a novel, stock 4 piston Brembo retained on the rear) and it is a dramatic change in braking performance. Definitely do not NEED the rear kit, but it is nice for reducing rotational mass and a stronger bite.
  11. tazandjan
    39,150
    I ran 135171 with 396 mm ceramic rotors and 6 pot calipers in the front and OEM FHP rears for a few years and that combo worked fine. Another owner did the same thing with a 456M and never fitted ceramics on the rear like I did.
  12. Chupacabra
    Chupacabra F1 Rookie
    3,522
    Behind a drum kit
    Mr. Chupacabra
    I did it all at once.
    Thakfully, from my perspective anyway, it is NOT a night and day difference. I have other cars for slinging about; I simply wanted to tighten the 575 up a little bit and improve some of the tactile experience, both of which were accomplished. The character and tractability remain but the car is certainly sharper now. I also have Trev360’s tune, so that moves the visceral appeal up a bit more as well.
    poljav likes this.
  13. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    I had ceramic rotors and pads made to spec for my tesla plaid, very happy with how it turned out
    Will do the same for my 575m after I get the exhaust on
    Not sure what wheel setup I want to do
    If I do 20" wheels
    front 405mm rear 380mm ~9100$
    If I do 19" wheels
    front 380mm rear 380mm ~8900$
    front 380mm rear 355mm ~8700$
    If I do 18" wheels
    front 355mm rear 355mm ~8500$
    Prices include calipers, brace disc, brake pads, and brake lines (full sets)
  14. Auraraptor
    Sep 25, 2002
    13,957
    MO
    Omar
    Thats a VERY good price. OEM HGTC conversion priced today is around 20k-25k for the brakes alone if you are very aggressive with sourcing parts.
    Passion_of_V12 and Ferrari55whoa like this.
  15. tazandjan
    39,150
    What is the source for the ceramics? Mine came from Mov'It.
    Ferrari55whoa likes this.
  16. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    #66 vraa, Mar 12, 2025
    Some OE company I found off alibaba
    They were making rotors for some race teams in EU
    I said what the hell let me try it out on my Plaid (1000hp)
    I have 0 complaints after 15k miles
    My tesla wheels similar situation, a company off alibaba, did a clone of the bbs aeros with higher load rating Image Unavailable, Please Login
  17. tazandjan
    39,150
    Wonder if they get the rotors from Surface Transforms?
  18. vraa
    vraa F1 Rookie
    4,586
    Texas
    Mr. A
    My vendor said no, its an in house 3d knitting technology, long fiber series, third gen product
  19. Auraraptor
    Sep 25, 2002
    13,957
    MO
    Omar
    So even better then HGTC (all I don’t know if they updated the rotor compound)
  20. tazandjan
    39,150
    Affirmative, just like my Mov'It rotors are two generations better than CCMs. Those should be one generation newer and even better.
  21. BillyD
    BillyD Formula 3
    1,825
    Pacific Northwest
    Bill
    My opinion of the FHP:
    Its too stiff for a GT car, though I didn't get to sample a non FHP car. Even having the 18 inch wheels/tires I cringe seeing the slightest bumps in the road. I also have to creep over speed bumps to prevent the car from bottoming out. Then theres the brake noise coming to a stop. Then theres my aching back and stiff neck.
    Of course this opinion is from someone no longer playing Speed Racer and taking freeway clover leafs at 100%.
  22. tazandjan
    39,150
    Bill- From someone who has been daily driving an OEM FHP 575M for 17 years, I will categorically disagree with you. Mine is definitely not too stiff for a GT, even with 19" wheels and lower profile tires.
  23. Chupacabra
    3,522
    Behind a drum kit
    Mr. Chupacabra
    Have to agree, after having the benefit of driving my non-FHP equipped car and my mostly FHP-equipped car a few days apart (and quite a bit post-upgrade), I haven’t noticed any harsh qualities or anything that makes the car any less comfortable. I certainly HAVE noticed more liveliness and better focus overall, but to be honest I have to be getting on it to really feel the majority of the difference…which is exactly what I hoped for
    Ferrari55whoa and Passion_of_V12 like this.
  24. TwoMinds
    TwoMinds Karting
    95
    London
    Colin C
    I agree. I'm soon about to put 1500 miles on my FHP equipped 575 over three weeks with not the slightest concern about harshness. And I have no brake noise on mine. In London, poor roads are ubiquitous but they are no more an irritation in the 575 as they are in my mini cooper. And I need a seat wedge in my mini otherwise my back aches after 15 minutes, but find the 575 supremely comfortable.
  25. tazandjan
    39,150
    The FHP brakes only tended to squeal much when they were new. Once bedded, they only rarely emitted a random squeal and that was only the front brakes, never the rears.
