355 - Fiorano Handling Package Vs Challenge Suspension ECU. | Page 11 | FerrariChat
355 Fiorano Handling Package Vs Challenge Suspension ECU.
Discussion in '348/355' started by ShineKen, Aug 17, 2021.
  1. C'dwic
    C'dwic Formula Junior
    Apr 23, 2021
    493
    France
    Ken ? React ?
    Hope all is fine for you, what do you.think about the white part # 178509 ?
  2. ShineKen
    ShineKen Two Time F1 World Champ
    20,080
    Southern California
    Nostradamus
    I believe I mentioned it is a hard challenge bushing (white). You can go challenge bushings all around if you want, but my latest discussion is more about finding a softer bushing solution.
  3. ShineKen
    20,080
    Southern California
    Nostradamus
  4. C'dwic
    Apr 23, 2021
    493
    France
    Good work Ken, you made the more hard...
    You have always your OEM manifolds ?
    Install tubistyle
    Try to see if your bushings are always softer behind.
    Is it possible to see me where is the pump for steering rack, i think in front of the motor...
  5. ShineKen
    20,080
    Southern California
    Nostradamus
    Not my car above.
    But yes I still have OE manifolds, which were the upgraded version purchased by the previous owner in 2005. Has about 13k mi and seems to be doing ok for now.
    Ferrari standard car sway bar bushings for 355 have always been rubber (red). But who knows, maybe I’m open to challenge bushings.
    308 GTB likes this.
  6. C'dwic
    Apr 23, 2021
    493
    France
    Philipnz and ShineKen like this.
  7. C'dwic
    Apr 23, 2021
    493
    France
  8. Skippr1999
    Skippr1999 F1 Rookie
    4,570
    So when is someone going to install the FHP on their Berlinetta and give us a report ? This thread has been going on for a longtime. Lets hear some results.
    308 GTB likes this.
  9. C'dwic
    Apr 23, 2021
    493
    France
    @ShineKen
    Look please, difference between yours and mine, 150415 is ok but look at was it written, A Cagnola MONZA, as your front ones… strange ?
    Have you got the information ?
  10. ShineKen
    20,080
    Southern California
    Nostradamus
    Ferrari used 3 different sources to produce springs during that time. But specs should be the same. Keep in mind the rear springs is a 512 TR spring.
    C'dwic likes this.
  11. C'dwic
    Apr 23, 2021
    493
    France
    Thanks Shineken !
  12. C'dwic
    Apr 23, 2021
    493
    France
    A Cagnola exists always or not ?
  13. ShineKen
    20,080
    Southern California
    Nostradamus
    Yes. Very old production source for Ferrari parts. Company still exists today.
  14. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    As a gentle reminder to those installing FHP on MY1994 and 1995 cars, it's important to upgrade your front shock mounts. The sheet metal up there is ~1.5mm thick and prone to cracking if you install upgraded springs.
    See these threads:
    My track day experience
    H&R versus Fiorano Springs
    What suspension parts (if any) to replace at 46K miles to improve handling
    Beginning with MY1996, the sheet metal and shock mounts were beefed up on production cars and the Challenge updates were no longer necessary.
    Pete (bobzdar) made preliminary modifications on his 1995 Berlinetta (my car's sister) and Elliott (MAD828) did the full upgrade: 1995 F355 GTS: Restoration and Major Service
    MAD828, OCKlasse and Qavion like this.
  15. OCKlasse
    OCKlasse Formula Junior
    711
    Newport Beach, CA
    Brandon K
    I actually had this issue after installing coilovers on my 95. The towers were subsequently reinforced, but it’s interesting to know that this common.
    308 GTB likes this.
  16. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    If you have a 95 and actually drive it, it will require it. Glad I did mine, and I can say for sure the addition of the Fiorano parts, rebuilt shocks, bushings and the challenge reinforced uprights were the best money spent on the car.
  17. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    My 2200 lb/in front Challenge springs caused considerable damage as you saw in the pictures I posted on those threads. My car never had the shock mount modification when it raced in the Challenge Series.
    Right, Elliott. Pete was beginning to see similar damage with his H&R springs. That's why I feel that anyone planning on upgrading springs on a 1994 or 1995 car should have the Challenge shock mount modification done.
    OCKlasse likes this.
  18. C'dwic
    Apr 23, 2021
    493
    France
    Mine is 99, i think i will have no problem, but is it possible to see what modification you speak ?, by picture, i will check..
  19. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    You already have the update from factory.
    308 GTB and C'dwic like this.
  20. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Yes, and on your 1999 car it will look just like the one on this 1998 F355 Challenge...
    C'dwic, Qavion and OCKlasse like this.
  21. C'dwic
    Apr 23, 2021
    493
    France
  22. JohnnyTT
    JohnnyTT Karting
    142
    NJ
    Is that a Carcoon???
  23. C'dwic
    Apr 23, 2021
    493
    France
