355 - Fiorano Handling Package Vs Challenge Suspension ECU. | Page 18 | FerrariChat
355 Fiorano Handling Package Vs Challenge Suspension ECU.
Discussion in '348/355' started by ShineKen, Aug 17, 2021.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,068
    Southern California
    Nostradamus
    I’m going to use this Serie Fiorano as an example.
    https://bringatrailer.com/listing/1999-ferrari-f355-spider-fiorano/
    Front height is set at roughly 10-15 threads up. According to my calculations, rake is either Omm or the car is higher in the front vs rear. My guess is alot of understeer is dialed in with this setup.
    Serie Fiorano owners should consider getting an alignment shop to setup up the car if he wishes to have the full factory recommended experience.
  2. ShineKen
    20,068
    Southern California
    Nostradamus
    Here is an FHP car (left) vs standard car (right). It appears owners are leaving the rear height untouched while raising the fronts. Standard 355’s can simply raise rear (to 191mm) to improve rake. FHP 355’s only have a small window of adjustments if one wishes to keep factory settings.
  3. ShineKen
    20,068
    Southern California
    Nostradamus
  4. ShineKen
    20,068
    Southern California
    Nostradamus
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,922
    Richmond
    Pete
    See the last line in the fhp supplement, that's why you're probably seeing a discrepancy.
