355 - Fiorano Handling Package Vs Challenge Suspension ECU. | Page 4 | FerrariChat
355 Fiorano Handling Package Vs Challenge Suspension ECU.
Discussion in '348/355' started by ShineKen, Aug 17, 2021.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,153
    Southern California
    Nostradamus
    @601
    Btw, for coil diameter I am plugging in 12 or 12.5mm.
    For spring diameter, I’ve tried 103 or 103.5mm.
  2. OCKlasse
    OCKlasse Formula Junior
    711
    Newport Beach, CA
    Brandon K
    Just cut one coil people and you, too, can have Fiorano springs :)
    ShineKen likes this.
  3. 601
    601 Karting
    Dec 19, 2010
    223
    California
    This photo shows more clearly where the coils start and end. I count just under 9 coils on the Fiorano spring (top) and just over 9.5 coils on the standard spring (bottom). So you're right, the difference is probably closer to one than 1/2.
    The first and last coil of each spring is inactive, so keep that in mind if you use a calculator that asks for active coils rather than total coils.
  4. ShineKen
    20,153
    Southern California
    Nostradamus
    #79 ShineKen, Sep 15, 2021
    Using 7 & 8 active coils respectively, with Fiorano coil diameter of 12.5mm and spring diameter of 103.5 mm , I’m getting 54% stiffer, which brings it to 285 lbs/in.
    If I use a spring diameter of 103mm , I get 57% stiffer. That’s 290 lbs/inch.
    Watchu got?
  5. 601
    601 Karting
    Dec 19, 2010
    223
    California
    You need to use calipers on the coil to get more precise. Your spring diameter range is fine, just pay attention to whether your calculator calls for inner or outer diameter.
  6. ShineKen
    20,153
    Southern California
    Nostradamus
    Just visually comparing the two, spring coil diameter is 1mm more than standard. Since standard is spec’d at 11.5mm, I use 12.5mm.
    Spring diameter has got to be either 103 or 103.5mm
    I plugged in 104mm just in case and got 52% stiffer. That brings it to 280 lbs/in.
    This is all under the assumption the standard spring is 185 lbs/inch.
  7. ShineKen
    20,153
    Southern California
    Nostradamus
    The calculator I’m using only asks for outer diameter.
  8. ShineKen
    20,153
    Southern California
    Nostradamus
    Using the same ruler to measure coil diameter on both springs, I’m pretty confident it is right at 1mm thicker for Fiorano. You can sort of see that 1mm thickness in the pics.
    This has got to be a 280-290 lb spring.
  9. 601
    601 Karting
    Dec 19, 2010
    223
    California
    Unlikely. It would sit too high even with the perches turned all the way down.
  10. ShineKen
    20,153
    Southern California
    Nostradamus
    Ok. I found two pretty accurate mm gauges.
    I measured standard front springs, standard rear springs, and Fiorano front springs. They all checked out close to WSM specs.
    Standard front - 11.7 mm
    Standard rear - 12.2 mm
    Fiorano front - 12.7 mm
    .2 mm difference from WSM must be the thickness of the powdercoat coating.
    Fiorano front coil spring is indeed 1 mm thicker than standard front. 12.5 mm. This is actually the same thickness as the Fiorano rear springs (150415).
  11. ShineKen
    20,153
    Southern California
    Nostradamus
    Only other thing I can think of is we have # of active coils wrong. That’s the only number that would make a big difference.
  12. ShineKen
    20,153
    Southern California
    Nostradamus
    BTW. My other spring is already at Swift. I’m just calculating to see how close my guess is :).
  13. 601
    601 Karting
    Dec 19, 2010
    223
    California
    The calculation for the spring rate in N/mm is as follows. Units omitted for simplicity.
    78,500 x 12.5^4 / (8 x 7 x (103.5 - 12.5)^3)
    This converts to roughly 260 lb/in.
    You’ll recognize your measurements in the formula and 7 is my visual estimate of the number of active coils. It's not a whole number in reality and that imprecision potentially causes significant error.
    As you’re aware, the testing will give more accurate results.
  14. ShineKen
    20,153
    Southern California
    Nostradamus
    This formula doesn’t factor in free length height?
  15. 601
    601 Karting
    Dec 19, 2010
    223
    California
    No, I requested free length for other reasons. Such as, we can use it to estimate spring rate based on the assumption that installed length would be similar as with the standard spring.
  16. ShineKen
    20,153
    Southern California
    Nostradamus
    Ok. I am using a general online calculator and free length was requested for calculations.
  17. ShineKen
    20,153
    Southern California
    Nostradamus
  18. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,641
    Elliott Caras
  19. ShineKen
    20,153
    Southern California
    Nostradamus
    You can tell your grandkids you bought the very last 355 Fiorano Handling Pack Ecu left in Ferrari inventory worldwide ;).
    MAD828 likes this.
  20. Skippr1999
    Skippr1999 F1 Rookie
    4,572
    Any update on all these spring and damper calculations?
    any conclusive info ?
  21. ShineKen
    20,153
    Southern California
    Nostradamus
    I have the Fiorano front spring rates test from Swift Springs. I'm going to re-test at Eibach to re-confirm. However, before I go there, I was trying my best to source a used set of the Fiorano rear springs, which is also a standard 512TR rear spring. Why used? Because the Fiorano front springs cost me $850 for the pair and the rear springs is going to be another $850. All this testing is adding up :).
    In short, I couldn't find the rear spring used, so I guess I'll bite the bullet (again) and get some new ones.
  22. Skippr1999
    4,572
    Nothing good in life is cheap ! Your research work is appreciated and in the end you’ll end up with the oem parts on your car which is what it’s all about.
  23. Skippr1999
    4,572
    sbenus and ShineKen like this.
  24. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,641
    Elliott Caras
    For full fiorano you want the brake pads, cross drilled rotors and the red calipers. But yes you have the full fiorano setup
    Itemized besides the brakes.
