355 - Fiorano Handling Package Vs Challenge Suspension ECU. | Page 5 | FerrariChat
355 Fiorano Handling Package Vs Challenge Suspension ECU.
Discussion in '348/355' started by ShineKen, Aug 17, 2021.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,153
    Southern California
    Nostradamus
  2. ShineKen
    20,153
    Southern California
    Nostradamus
    Problem is, the only thing available brand new on that list is the rear sway bar :). You can certainly try though.
    Apparently, someone bought the NOS Fiorano/512TR rear springs. Someones been reading my posts :).
  3. Skippr1999
    Skippr1999 F1 Rookie
    4,572
    Just making a list of parts in one spot. The hunt is on…
    ShineKen likes this.
  4. ShineKen
    20,153
    Southern California
    Nostradamus
    … and there you have it folks. The last brand new F355 OE Fiorano rear spring set left in the world. They are made by Eibach (commissioned by Ferrari. Not available from Eibach), just like the standard springs. It’s progressive profile is clearly shown. Now it’s time to do some testing :).
    MAD828 likes this.
  5. Skippr1999
    4,572
    You tha man
  6. ShineKen
    20,153
    Southern California
    Nostradamus
    How’s your search going so far :)? Let me know if you find a front sway bar :p.
  7. ShineKen
    20,153
    Southern California
    Nostradamus
    Regarding sway bar bushings, I believe Energy Suspension has proper replacements, but I’ll have to double-check.
  8. Skippr1999
    4,572
    haven't had time yet, but it's coming soon.
  9. ShineKen
    20,153
    Southern California
    Nostradamus
    Comparison with standard springs (far left and right)
    Manufacturers:
    Fiorano Front - A. Cagnola Monza
    Fiorano Rear - Eibach (Germany)
    Standard Front - Eibach (Germany)
    Standard Rear - Unknown. Has brass ring around coil with part number. Most likely same as whoever made the sway bars.
    Ferrari was all over the place when it came to choosing who to use to produce springs.
  10. ShineKen
    20,153
    Southern California
    Nostradamus
    Fiorano rear springs. At the highest points, with the set I received, one spring is noticeably a few mm higher than the other. Fronts were pretty close in height. These are all new, never installed.
  11. ShineKen
    20,153
    Southern California
    Nostradamus
    day355, MAD828 and Yassa like this.
  12. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,641
    Elliott Caras
    Yassa and OCKlasse like this.
  13. ShineKen
    20,153
    Southern California
    Nostradamus
  14. Skippr1999
    4,572
    Excellent find. Looking forward to hearing about the results on a Berlinetta
  15. 601
    601 Karting
    Dec 19, 2010
    223
    California
    Might call first to see if they're equipped to make splined bars.
  16. ShineKen
    20,153
    Southern California
    Nostradamus
  17. 601
    601 Karting
    Dec 19, 2010
    223
    California
    Probably because the front bar is splined.
  18. ShineKen
    20,153
    Southern California
    Nostradamus
    There is some discussion of running the rear bar being adequate, but I don’t have the experience to comment on that.
    T.W.S made splined bars for the 360, so they definitely can.
  19. 601
    601 Karting
    Dec 19, 2010
    223
    California
    I would say it's the other way around. The front needs more roll stiffness on the 355.
    day355 likes this.
  20. ShineKen
    20,153
    Southern California
    Nostradamus
  21. ShineKen
    20,153
    Southern California
    Nostradamus
    For those who have FHP, are your brake pads yellow front and rear or front only?
  22. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,744
    From memory, but I'm pretty sure the front and rear references on the service data sheet are exclusively Pagid Yellow all around, a little more abrasive than Ferrodo.
  23. ShineKen
    20,153
    Southern California
    Nostradamus
    Do you know which Pagid Yellow specifically?
  24. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,744
    Yes, a friend had put some on the original discs of his 355 and... too much abrasive
