Fire Extinguisher mount again | FerrariChat
Discussion in 'Technical Q&A' started by ferraridriver, Mar 8, 2005.
  1. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,151
    Bay Area Calif.
    Dave
    #1 ferraridriver, Mar 8, 2005
    I’ve been asked several times to repost pictures of my fire extinguisher mount which were lost in the archive crash
    So here is a set which I just did today.
    I got the extinguisher on Ebay for $110, it has two clamping straps, and the handle doesn’t stick out as far as some I’ve seen.
    As you can see there are no holes drilled, and it can be removed without a trace it was there.
    You pull the whole extinguisher up to adjust the seat
    I’ve had this set-up since 1999, and it has been no problem for my wife who is 5 ft. short, or any other passengers
    This is on a 355, but should work on any seat with a pull bar adjustment.
    ShineKen likes this.
  2. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Nice and simple, but that won't work on earlier cars that they have a different adjustment setup. For those, check out www.tradetutor.com/raceprep/
  3. f355spider
    f355spider F1 World Champ
    18,044
    Nor will that work on 355's with electric seats, like in the spider.... :(
