fire extinguisher | FerrariChat
fire extinguisher
Discussion in 'Technical Q&A' started by adesalos, Dec 1, 2003.
  1. adesalos
    adesalos Formula Junior
    Mar 19, 2003
    252
    Texas
    Search threads but couldn't find what I wanted. Thus, here is my question:
    I want to purchase a fire extinguisher (halon or halotron?) to place in my car (79 308). Any recommendations regarding the type, the size, and the vendor?
    I also want to attach it on the ground under the passager side, or behind the seat. Any recommendations regarding the location, and a bracket system to put it in?
  2. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    A nice way to secure your Halon extinguisher on the passenger side is with the "Charness Harness." I've done it this way (Thank you, again, Michael).
    See his website at:
    http://www.tradetutor.com/raceprep/
    Barry
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    There just isn't any room to mount it on the ground under the passenger side. The floor pan is level with the bottom of the rocker panel.
    Ditto for behind the passenger seat, unless you only have short-legged passengers.
    The commonly used locations are in front of the passenger's seat, vertically between a GTB's seats, or under the A/C duct over the front of the console. A few have routed it alongside the consold on the passenger's side, but that really crowds the leg room.
    Keep in mind that if you need it, most likely you'll want to grab it as you are bailing out to deal with an engine compartment fire. You won't have a lot of time to go digging it out from somewhere.
    Something I've considered is a cable activated extinguisher with plumbing to spray the entire engine compartment. The cable would be cockpit accessable, with a possible 2nd cable under the rear bumper.
  4. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,092
    E ' ' '/ F
    Snike Fingersmith
    See http://www.ferrarichat.com/discus/messages/6532/276396.html for a thread on the Charness Harness and some final pics. There's also a link in that thread to another discussion about what extinguisher to use.
  5. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    here is my set up.
  6. adesalos
    Mar 19, 2003
    252
    Texas
    Tillman, the link to the conversation about which extinguisher to use is cut.
    Any recommendation as far as the size, brand, type of extinguisher to buy?
  7. GrigioGuy
    Nov 26, 2001
    33,092
    E ' ' '/ F
    Snike Fingersmith
