First 355 oil change... success (with one hiccup) | FerrariChat
Discussion in '348/355' started by FCOnyx, Dec 27, 2013.
  1. FCOnyx
    FCOnyx Formula Junior
    May 28, 2012
    413
    Round Rock, TX
    Jeff
    Did my first 355 oil/filter change today. Smooth as silk. The Ricambi kit is fantastic. Just make sure you have a 12mm Allen. Even with a fairly extensive toolkit the largest I had was a 10mm (socket and key) so I had to make a tool run during the process. Finding a 12mm turned out to be a bit harder than expected, but Harbor Freight saved the day after 3 other stores failed.
    The only hiccup came when I pulled the filter. What do you guys do to keep about half a quart of oil from pouring from the filter when you loosen it? Twin streams went all over the sides of the gearbox all the way down to the garage floor. Not a big deal to clean up, but I'd like to improve my technique next time so no oil hits the engine at all.
  2. Ricambi America
    Sponsor Owner
    My technique (which is probably despised by many) was to punch a few holes in the filter while the drain plug was open. This allowed much more oil to drain through.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Did you do this with the oil hot? I'm told that's the proper way but also the way to get unavoidable 3rd degree burns ;-)
  4. M3S2k
    M3S2k Karting
    Jan 30, 2007
    53
    Manitoba, Canada
    Steve
    I always punch a hole in the filter and then slightly crack it loose to allow the filter to drain completely. Don't own a ferrari yet, but worked on my Lotus, etc. so should work here as well! This way no spill on the motor and doesn't cover your hands when spinning it off!
  5. FCOnyx
    May 28, 2012
    413
    Round Rock, TX
    Jeff
    @Dave: Yup. Warmed it up all the way to temp before pulling the plugs/filter.
  6. FCOnyx
    May 28, 2012
    413
    Round Rock, TX
    Jeff
    @Daniel: Sounds like a good solution to me. I'll try it on the next one.
    And thanks again for the great kit! I especially like the quality of the gloves. Thicker and less tear-prone than the usual Nitriles I've used. Kept me from using/ruining my Mechanix. ;)
  7. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,024
    PA
    Kevin
    I fit plastic bags under the oil filter assembly before removing the filter. Use the built-in drain of the housing to channel any oil into the bags. Have another bag ready to insert the filter as soon as it is unscrewed. I learned all this the hard way, of course.
  8. Redlyne_mr2
    Redlyne_mr2 Formula Junior
    Aug 5, 2009
    474
    Calgary, Alberta
    Ryan D
    I bought the oil filter kit from Ricambi. Does anyone know if it comes with the oil drain line crush ring? I would imagine not but wanted to check before I order some from Ricambi.
  9. Ricambi America
    Sponsor Owner
    No, it does not.
    The standard kit includes the oil filter, drain plug for the sump, drain plug for the tank (Hill Engineering), the 2 different copper crush washers for the plugs, and a pair or Nitrile gloves.
    The washers for the oil tank lines are not standard crush washers. They (145191,144485, and 144487) are rather expensive teflon/aluminum dual ring washers. Unless you have extenuating circumstances to open the lines, there isn't much reason to do so for a normal-old-oil-change.
  10. CANDREAM
    CANDREAM Canada
    Nov 13, 2009
    407
    Burlington, Ontario
    Sadi
    I usually leave the engine plug open for about 30 min to drain all oil from the filter....very min oil leaks which can be caught as soon as you remove the filter.....patience....engine warm.
  11. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    In my experience if you leave the drain plug out long enough say 30 min or so there won't be any oil left in the filter.
