First flat | FerrariChat
First flat
Discussion in '458 Italia/488/F8' started by aggiestckl, Mar 4, 2018.
  1. aggiestckl
    aggiestckl Karting
    Jul 15, 2016
    238
    Doylestown, PA
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Hit small pot hole and although no apparent rim damage lost the PIRELLI p zero front passenger side
    Was quite a task to get on flat bed with the Novitec front splitters
    Got it on and home and put on jack stands. Will be buying some Michelin Supersports for summer and saving these from whatever
    Figured out how to put on jack stands. Not overly difficult but not quite as easy as a R8
  2. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    How did you get it on the stands ?
  3. aggiestckl
    aggiestckl Karting
    Jul 15, 2016
    238
    Doylestown, PA
    MANDALAY likes this.
  4. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    Pothole?
  5. aggiestckl
    aggiestckl Karting
    Jul 15, 2016
    238
    Doylestown, PA
    yes nasty one.. good reason to get new pilot super sports all around. Got them installed yesterday.. perfect
  6. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    #6 Melvok, Mar 6, 2018
    PLEASE !! Do be very carefull ...
    It is quite dangerous to have a car on 4 of these stands ... every garage man will tell you how often a car drops off with these small posts.
    Far better is to use blocks of any substance that can not tip over ever ....
  7. Melvok
    Jul 25, 2008
    14,268
    Mel
    Bad luck ... a pothole ... and no rim damage ...
    I wanted to start a thread about What Will You Do when you get a flat ! So I do not want to hijaack your thread ... Do you mind ? :)
    Chime in here ....
    If this happens to you way ... way back on a tour ... What choices do you have ?
    There are (sometimes) some options ...
  8. RayJohns
    RayJohns F1 Veteran
    7,929
    West Coast
    Ray
    who makes those Jack stands?
  9. spyder625
    spyder625 Formula Junior
    Jun 16, 2017
    727
    NJ
    crazy, i dont look forward to ever getting a flat.. but thanks for sharing
    Melvok likes this.
  10. gqa
    gqa Formula Junior
    Feb 10, 2011
    469
    NY NY
    I keep a tire plug kit in my car. Saved me from additional headaches twice and saved a friend in a 430 too!
    However it won't help you with a blowout or rim damage such as the OP but its waaay better than waiting for a flatbed.
  11. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,467
    Plug kits good only for tread puncture as are the foam inflators but good only in a pinch
    A cracked rim the foam may work for a short while if is small enough
    Sidewall blowout- u are done- even cars with run flats can’t survive more than a mile or two before they fail completely
  12. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    I keep a plug kit in my car as well. Haven’t needed it yet but as gqa said it can save you if just a nail in the tread.
  13. spyder625
    Jun 16, 2017
    727
    NJ
    great simple insurance...
  14. Melvok
    Jul 25, 2008
    14,268
    Mel
    Sidewall blowout will definte criple you for some time ..... see the full rip rhs of the nipple ....
    And where are you getting the right new tyre ?
    Took my friend 3 days in this case .... (plus hotel nights ect ...) :eek:
      File size:
      61.7 KB
      125
  15. aggiestckl
    aggiestckl Karting
    Jul 15, 2016
    238
    Doylestown, PA
    They are esco flat tops
  16. aggiestckl
    aggiestckl Karting
    Jul 15, 2016
    238
    Doylestown, PA
    The small posts are exactly the same diameter as the lifts. It has very large feet and I feel you’d need Superman strength to move the car off one of these
  17. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    One question, if I may: Do you have the TPMS and, if so, did it work correctly and warned you in time?
    Kind regards,
    Nuno.
  18. aggiestckl
    aggiestckl Karting
    Jul 15, 2016
    238
    Doylestown, PA
    Yes worked perfectly
    AlfistaPortoghese likes this.
