first gear (no. 523334) | FerrariChat
Discussion in '206/246' started by GermanDino, Feb 23, 2017.
  1. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #1 GermanDino, Feb 23, 2017
    I´m looking for a first gear (no. 523334), same for 206 GT, L- and M-series
    Tav 22, no. 13 in the M-series parts catalogue
    Any help appreatiated
  2. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    Matthias, how many teeth does it have?
    I will look around.
    Regards, Alberto
  3. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    Are the gears the same as early Porsche? I heard that somewhere. They are under a Porsche patent.
    Freeman
  4. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    I show that gear to have 40 teeth.
  5. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #5 GermanDino, Feb 23, 2017
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    I believe that it is the synchomesh system that is the same as Porsche and used under license to Ferrari. The gears AFAIK are specific to Ferrari
  7. racerboy9
    racerboy9 F1 Rookie
    2,649
    Might check with T-Rutlands as they had many gears years ago when Ted would let me roam around the warehouse. Some of their stuff at the time was not in their database. I would send a picture and the tooth count.
  8. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    #8 swift53, Feb 23, 2017
    The same synchro carrier as an Alfa Romeo, without the gear, as it can be replaced and picked out from a high gear, because of less use (also kinder).
    The transmissions become rather simple, once you take them apart and reassemble a few times.
    Regards, Alberto
  9. 4redude
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    Hello Matthias, I think I have found a gear. It is used but appears to be very good condition. I will get some pictures for you.
  10. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    I found the correct one here in Germany... thanks for all the help...
