First owner's post | FerrariChat
First owner's post
Discussion in '308/328' started by tiredtom, Jul 26, 2012.
  1. tiredtom
    tiredtom Karting
    Feb 26, 2012
    85
    Monterey County, CA
    86 328 GTS
    After a long, patience testing search, I got an 86 328 GTS today. It's so nice (to my eyes, anyway) that I was a nervous wreck driving home. I might was well use my first owner's post to begin the obsessive sensitivity to all issues, real and imagined.
    Here we go: The driver's door squeeks from the detent bar (likely the wrong part name, but not from the hinges). I sprayed a small amount of lube in there to no effect. Suggestions?
  2. stevel48
    stevel48 Formula 3
    Jan 4, 2005
    1,998
    Metrowest MA
    Steve (85 308 Owner)
    Congrats on the car. Lithium grease maybe? Also check the hinge pins. They ten to loosen and ride up over time
  3. jcinflorida
    jcinflorida Formula Junior
    Oct 24, 2009
    331
    Melbourne Florida
  4. Euro Quattro
    Euro Quattro Formula Junior
    Apr 20, 2005
    344
    Vancouver
    Kent
  5. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Congrats.
    Enjoy.
    Relax, let it warm up then give it hell. Otherwise don't waste your time.
    You'll get there.
  6. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Excellent Tom, now show us pics...we LOVE pics!
    For the door squeak, if that's your only problem, then you are really blessed.
    Just clean it real good and lube it like Steve said.
    If the door falls off, replace the hinges...just kidding...don't let it get that far.
  7. tiredtom
    tiredtom Karting
    Feb 26, 2012
    85
    Monterey County, CA
    86 328 GTS
    The door hinge pins appear to have zerk fittings? I'll try a little moly.
  8. jsa330
    jsa330 F1 World Champ
    10,047
    75225
    Scott
    Mine get squeaky at intervals and I use spray lithium grease. Works well.
    Welcome to Ferrari ownership. May your timing belts not break and your net worth not diminish (by much, at least)
  9. sammyb
    sammyb Formula 3
    Jun 23, 2006
    1,857
    Where wife tells me
    Sam
    Welcome to the wacky world of '86 328 ownership. You will find at least one answer to every 328 issue here. Search first, but if you don't see a good explanation to your issue, don't hesitate to post.
    The 328 GTS/GTB has many idiosyncracies that are well documented...but it's also the most robust Ferrari ever made. In other words "good choice!"
    So what colors are your car (exterior/interior)?
    Sam
    ('86 Blu Medio/Nero(black) interior)
  10. conan
    conan Formula Junior
    Nov 13, 2011
    389
    Welcome to the FC and Ferrari world. I also experienced the same thing on my '86 328. It looked very good at first, but under the hood a lot of small things are slowly breaking apart - coolant hoses, heating hoses, belts, water pump, gas hoses, door handle pins, ignition leads, cam shaft oil seals and much more.
    Most of these can be easily fixed but it may be hard to see there is an emerging problem and also somewhat time consuming to get to the location. Many things may have to be taken out of the car first.
    Most important is to always pay attention to noises. If there is a slight squeak from the right side of the engine bay - a belt is doing something nasty. Check it out.
  11. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    Congratulations, Tom.
