First post, need help with a 308 | FerrariChat
Discussion in '308/328' started by Dallas308, Sep 14, 2019.
  1. Dallas308
    Dallas308 Rookie
    Sep 14, 2019
    4
    Bernie M.
    #1 Dallas308, Sep 14, 2019
    Hi, I’m helping a friend tune up his 308 GTSi. Problem is, I’m not sure what year it is.
    VIN says it’s a 1980, but rear panel says 308 quattrovalvole, which I understand did not come out till 82, and that QV logo in the back, I have only seen it in 83- and later models. Also, the steering wheel is the triangular non perforated type, which I have read came out later. It does not have the grille on the hood which I have seen in all the QV’s, It does not have the Ferrari badges on the fenders between the front wheels and the door, The wheels are 17” and do have the Ferrari logo in the center.
    Does that description sound like a 1980?
    I’ll post some pictures if I can figure our how.
    Du_Man likes this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Does the intake plenum says Quatrovalvole and can you post some pics? 1980 has the clock and oil temp gauge mounted vertically.
  3. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,326
    Montana
    Kim
    Me thinks someone stuck a Quattrovalovle emblem on an earlier model.
  4. djs308
    djs308 Formula 3
    1,132
    Long Island, NY
    David S.
    I'd believe the VIN in this case. Decoding the number will tell you exactly what it is. Also, AFAIK no 308 left the factory with 17 inch wheels or fender badges. Most likely, the other items have also been added on.
    Eforg23 and waymar like this.
  5. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    What is the last 5 vin digits?
  6. Dallas308
    Dallas308 Rookie
    Sep 14, 2019
    4
    Bernie M.
    Here are some pictures.
  7. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,215
    Gold Coast, Aust.
    Patrick
    308 GTSi. 2 valve engine with Bosch fuel injection
  8. DonB
    DonB Formula Junior
    626
    Florida
    Don Bartz
    RUN, RUN away just as fast as you can! The thing looks like a basket case.
    TJsBeer likes this.
  9. topcarbon
    topcarbon F1 Rookie
    Nov 3, 2006
    2,605
    I feel sad
    Dane and TJsBeer like this.
  10. Dr Tommy Cosgrove
    36,405
    Birmingham, AL
    Tommy
    It's an 80. No question.
    And needs more than a tune up
    mwr4440, TJsBeer and 308 milano like this.
  11. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Not a Quatrovalvole that’s for sure.
    308 milano likes this.
  12. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,146
    SanFrancisco BayArea
    1983 US 308 GTS QV
    The main items that people are using to conclude its not are QV are as follows:
    - intake plenum is the type used for the fuel injected 2 valve engines (1980 to 1982)
    - speedometer indicates only to 85 mph; used only on fuel injected 2 valve engines
    - oil temp and clock gauges are vertically stacked; QVs had them horizontal.
    - front hood has no louvers; QVs had louvers
    The A and B pillars are body colored, which only began in 1984 when Ferrari was simplifying their painting efforts. It probably means the car has been repainted.
    Cosmetically the car clearly needs work but that only incriminates mechanical condition. It's not an indicator.
    The serial number for the car is very unusual.
    NoGoSlow and TripleBlack like this.
  13. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    #13 308 milano, Sep 15, 2019
    If you have this machine running big congrats!
    Appears it has set for a very long time. I would highly recommend you change all the fuel/vapor lines before taking it out of the driveway. Also would do a timing belt / bearing change before moving it. Not expensive just time consuming. Lots of really good people here that can give you step-by-step instructions on what’s needed and how to proceed . Keep us posted on your progress! :)
  14. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,215
    CT
    John Kreskovsky
    Obviously been repainted from the 1st picture in post 6, at least partially. This car need a full restoration at least, if it can be saved. I'd bet if stripped to bare metal it would be a Bondo Queen. I could be wrong about the Bondo, but an 80, in that shape, without rust?????
  15. Dr Tommy Cosgrove
    36,405
    Birmingham, AL
    Tommy
    Impossible
  16. Dallas308
    Dallas308 Rookie
    Sep 14, 2019
    4
    Bernie M.
    Thanks to everyone for the quick responses.
    This is my friends car, and I’m just trying to help him sell it. When I said tune it up, I meant to say, tune up whatever is wrong with it, not just the engine. The car has not been driven in about ten years. It starts and idles fine, but after it warms up, it runs rough. I’m sure the brakes, fuel lines and other things will need to be replaced. So far, the mechanic said that it appears that the fuel injection pump needs to be replaced, he said that they are around $3300. Can they be rebuilt?
    It is obvious that the car has been repainted, Where would rust be apparent?
    So probably the rear panel and steering wheel got replaced?
    Are there two fuel pumps? A lift pump and an injection pump?
    What seems strange with the serial number?
    What about the wheels? Are they by Ferrari or aftermarket?
    Are there shop manuals available for this vehicle?
  17. Dr Tommy Cosgrove
    36,405
    Birmingham, AL
    Tommy
    I would not try to fix it if you are selling it. Just sell it as is.
    You will never EVER get in the black with an 80 308 in that shape.
    thorn, BrockBenson, dflett and 2 others like this.
  18. Dr Tommy Cosgrove
    36,405
    Birmingham, AL
    Tommy
    The wheels are aftermarket.
    And there really isn't a shop manual for that car like you are used to seeing with something else.
  19. miketuason
    Feb 24, 2006
    15,806
    Cerritos, CA.
    The center cap of the wheels are obviously wrong, looks like it came from a different type wheels.
  20. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,146
    1983 US 308 GTS QV
    There is only one fuel pump. The pump pulls fuel from outlets at the bottom of the tanks so no in-tank lift pumps are needed. Precise fuel pressure is critical to the proper operation and is regulated by a pressure regulator. There are two fuel tanks on either side of the front of the engine. The Bosch K-Jetronic system is brilliantly simple. The injectors spray continuously. The amount of fuel they spray is regulated by the large unit in the rear right corner of the engine compartment. A key component in there is a big flapper valve that measures airflow and meters fuel appropriately. It's a pretty cool system; robust and stable.
    The serial number may just be a coincidence. It's just odd that the last five digits are xx001.
  21. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Quoting because this is the truth. Now that you can prove it runs, if you are going to sell, sell. No dollar you put into it will come back to you.
    dflett and 19633500GT like this.
  22. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    And don't expect a high-dollar buyer for that car, in that condition.
  23. Du_Man
    Du_Man Formula Junior
    320
    Dallas, Texas
    Derek
    Hey Dallas308........Let me know if you are in the Dallas area. I am looking for a 308 to fully restore. I live in the DFW area.
  24. Du_Man
    320
    Dallas, Texas
    Derek
    I guess one (POST) and done. Let me know if anyone sees other sad 308 orphans!..... or know of Dallas308's contact info.
  25. Dallas308
    Dallas308 Rookie
    Sep 14, 2019
    4
    Bernie M.
    Hello, I was on vacation and just got back. I am in Dallas
    Hello, I was on vacations. I am in Dallas, how can we get in touch privately?
