First Problem with the Pcar | FerrariChat
Discussion in 'Porsche' started by PhilNotHill, Aug 20, 2015.
  1. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    2011 Boxster S with 23k trouble free miles.
    Partial TPMS warning came on. Was able to reset but after 30 minutes the warning came on again. Right front tire shows a blank...all the other tires read normal.
    Called the Indy shop and was told the sensor contains the battery and the whole unit has to be replaced. Costs $200 and $100 for labor.
    Does not effect the driveability of the car. I could wait until the tires need replacing in about a year but my wife doesn't want to wait that long. Earliest appoinment is a month out. Not worth driving 3.5 hours to Denver to get the car fixed sooner.
    Guess we shouldn't complain. No issues yet. Only regular maintenance. Friend has a spyder which he bought about the same time. Had to replace the water pump at a cost of about $400!
  2. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    That seems like a lot of money for the sensor, I bought 4 for a second set of wheels for one of my Porsche's and it was not much more than that.
  3. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,508
    Honolulu, HI
    Phil, I got my TPMS from Titan TPMS. They carry the OE Huf Beru, OEM Huf, ITM and Oro-Tek. My 08 Boxster needed all four and got the ITM for $180 shipped. Costco installed them for me and 5 miles later, the TPMS system was up and running.
  4. PhilNotHill
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Thanks for the heads up.
    The light has not come on for two days. Will cancel the appointment if it stays out until the appointment.
  5. Ferranki
    Ferranki Formula Junior
    Mar 9, 2007
    773
    Buffalo NY
    Ken
    Had a problem, so at 40k on my '07 TT replaced them all when I changed tires. Dealer said that was normal.
  6. Devilsolsi
    Devilsolsi F1 Veteran
    9,314
    MD
    Alex
    Be sure to check your tire pressure if the light is on just in case. A couple years back the light came on in my car and I figured it was just due to cold temps. I couldn't feel any difference in how the car drove since it was on low profile performance tires. Figured I would check the pressure when i got home that night. Ended up ruining the tire driving on it.
